Results 1 to 10 of 10
Thread: Day 2 of the Shade Structure
    5,172
    Didn't get a lot done today but did come up with a more predictable process. All 4 posts now have tenons milled on them. Sorry, too dark when I finished to take a picture.
    I did spend considerable time getting two mortises housed and fitted. That was the most predictable process. First I draw out the post position on the header. Then I mark of the center of the holes to be drilled to hog out the waste. I set out the outline with a 1 1/2" chisel and a dead blow hammer.
Name:	G Marking out the nortise.jpg
    After drilling the holes, I chopped out the waste. Getting holes to the right depth eluded me for a while until my brain kicked into gear and I set a few gauges to measure the depth. Trying to remember numbers and read rulers each time is a recipe for error. Set the gauge and then I don't need to remember the number.
    Part of the problem was that I intended to house the post and that 1/2" more in depth didn't translate to the hole depth until the first tenon didn't fit for depth! Re-drilled and cleaned out the bottom and I was good to go.
    Somebody mentioned no routers up to this point. Well, here you go! I sawed the housing for depth and then set the router bit depth to clean out the housing.
Name:	H Setting router bit depth.jpg
    Purty, ain't it?
Name:	I housed mortise routed flat.jpg
    And, the final fit.
Name:	J Housed tenon & mortise joint done.jpg
    Next up are the knee braces. This out to be interesting.
Name:	knee brace.jpg
    30,017
    Looks good, Carol. You obviously still know your way around the woodshop.
    13,361
    Very nice!
    3,134
    Great work Routa Lady strikes again.
    Yorktown, Virginia
    5,015
    Router sighting!! Now we're getting somewhere
    I have been playing with D-Handle ideas for a couple of my routers. I was over-thinking it and although not the focus of your thread. the picture of the router plate handle is a winner for me. Go, Carol, Go!
    5,172
    Plans for the Big Foot for the router are in my previous book. If you don't have that, trace a hand saw handle you find comfortable. Adjust the bottom for the angle most comfortable for your wrist. Draw a circle slightly larger than the router base. Measure out for the handle base. Draw an arc around the back of the handle. Dra straight lines tangent to the base circle, and there you have both the pattern for than handle and the pattern for the base.
    4,699
    What are you going to do for pinning the mortises or are you just going to rely on glue?
    5,172
    No glue on timber framed structures. Since this structure will be moved, I am going to use 3" screws. When it is moved and set up in its final destination, white oak pins will replace the screws.
    3,132
    Carol are you using timber screws or just 3" galv screws?
  1. repairing a lamp shade base
    Last Post: 07-19-2015, 02:56 PM
  2. Sysamore Lamp Shade an Base
    By Roy Millsaps in forum Lathe Project Showcase
    Last Post: 08-07-2014, 03:30 PM
  3. Shade Structure Build
    By Carol Reed in forum Carpentry and Construction
    Last Post: 05-26-2014, 04:43 PM
  4. Turning a Lamp Shade - Who here showed this guy how to do it?
    By Pete Simmons in forum Lathe Project Showcase
    Last Post: 04-09-2013, 10:30 PM
  5. Lamp and Shade......what a wonderful experience!!!
    By Joan Keeler in forum Lathe Project Showcase
    Last Post: 04-23-2009, 05:13 AM
