Results 1 to 1 of 1
Thread: Part 2 - Timber Framing Tutorial
    5,172
    This part should catch up to where I am, so it will be long. But lots of pictures.
    To begin, here are my main go to tools and the redneck sharpening station I set up.
Name:	O most used tools.jpg
ID:	83062 Click image for larger version.
Name:	N reedneck sharpening.jpg
    To sharpen (often) I simply slide the back of the chisel on the 240 grit PSA sandpaper 3-4 times. Then I draw the bevel side backwards twice. Works real well.
    So I began with a side header. I cut the 16' 4x4 down to 15" long.
Name:	S cutting posts to length.jpg
    Then I cut 2 16' to 8' lengths for the 4 posts. They each needed a 2x2x2 1/2" tenon on one end. I needed some practice first. I can tell you muscling 16' 4x4's around is not work for an old lady. Had to get into the Aleve bottle. Dimension lumber is wet and very heavy.
    I used the 1 foot cut off to make a sample tenon. I cut the shoulders of the tenon with the SCMS to 3/4" deep. Then I cut the cheeks by hand with the pull saw. This was not particularly accurate or acceptable.
Name:	B Test Tenon.jpg
    I decided to face off the tenon cheeks with a router.
Name:	H Setting router bit depth.jpg
    I set the bit depth to 3/4" and put a Big Foot base on my router. You can find plans for that in my router book, Router Joinery Workshop. The issue with this is that I am measuring waste with the idea of having a finished part to the correct dimensions. This is a real good place not to assume anything! But we prevailed. Cutting the tenons by hand was way too much work! I had lots more tenons to cut. I decided to borrow a friend's band saw for the next batch, as mine is unavailable. But I did get the posts done the hard way.
Name:	R completed post tenons.jpg
    Now I went after the housed mortises in the headers to receive the posts. Since I finally had tenons all the same size I could use my sample tenon to measure and mill the mortises. Turns out that process needs some work before I mill the rest of them, too.
    I marked out the mortise by drawing the outline and setting the lines with the chisel. Then I drilledl four 1" holes with a new spurred spade bit.
Name:	G Marking out the nortise.jpg
ID:	83070 Click image for larger version.
Name:	C Start Mortise.jpg
    Then chop the waste with the sharp chisel.
    Now the housing part. I inserted the test tenon and marked the edges of the housing and hand cut to 1/2" deep. Back to the router, this time set to 1/2" and cleaned out the housing face.
Name:	I housed mortise routed flat.jpg
    Ooops. Hit the picture limit.
    To be continued.
  1. Some Timber Framing
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 01-07-2015, 03:16 AM
  2. Part 3 - Timber Framing Tutorial
    By Carol Reed in forum Carpentry and Construction
    Last Post: 05-29-2014, 03:51 PM
  3. Part 1 - Timber Framing Tutorial
    Last Post: 05-28-2014, 11:43 PM
  4. Timber Framing
    By Tyler Howell in forum General Woodworking Q&A
    Last Post: 02-25-2009, 09:57 PM
