Results 1 to 10 of 14
Thread: Anyone used Rustoleum Restore for decks?
    Honolulu, Hawaii
    1,103
    Hi all.
    I am wondering if anyone has used this product for refinishing your wood deck? My daughter and son-in-law are doing theirs and have bought Restore to coat the deck after pressure washing it with a cleaner.
    I have read some reviews of the product and found adhesion and peeling to be a problem. Just wondering what your thoughts and experiences were if you had used it..
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    17,475
    tony i havnt used it but know where it has been used and it has held up well,, many years of use.. be sure to get the deck DRY before coating it.. i have intentions of using it on my parent front door landing aera.. it appears to be a good product.. will be watching the thread to see if others chime in with there experiences on it.
    Yorktown, Virginia
    5,021
    Tony,
    My neighbor used it last year and it has held up well. I tried out the Olympic Rescue product on my deck railing and steps earlier this year and so far they have held up well. I read the reviews on both products and was kind of skittish about committing all that money to do the whole deck, so I decided to do a test on the rail and steps. If it makes it through this next winter, then we will do the whole thing.. Lots of surface prep required. You have to fill all the cracks larger than 1/8" and make sure no loose stain/paint. I ended up belt sanding and scraping off the old finish and filling cracks with indoor/outdoor spackle. It's holding so far.
    13,454
    Was considering using it on our pool deck (concrete), but will probably hold off another year or so, or if we decide to sell to spruce it up some.
    Rochester
    846
    I experimented with the Restore for our deck before committing the money for the whole thing. I had a tough time building up the textured surface so that it looked good....no matter what I did, it looked sparse. It could have been my technique, but I ended up not using it for the whole deck. Instead, I opted to rent a drum sander and restored the original surface.....$75 and 4 hours very well spent.
    Got Wood?
    Jan 2011
    Hudson Valley NY
    122
    Hi Tony, I used this on our pool deck. The decking is on the ground and is 22 years old and looked it. This really saved me from replacing the deck. We opened the pool this weekend and the deck still looks like it was just done. If you use it make sure you use the restore roller or you will not get the texture.
    Apr 2009
    Outside the beltway
    5,260
    I've always liked Rustoleum products, We are getting ready to do my son's deck and the drum sanding bit too Scott.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    17,475
    in order to sand it you must have to take out the screws or nail right?,, and Sayer what prep did you do before laying it on?
    Apr 2009
    Outside the beltway
    5,260
    Thanks Larry. Actually I was thinking of pulling all the boards and flipping them.
    Jan 2011
    Hudson Valley NY
    122
    The only prep was a good power washing. Like Dave, I also flipped some of the boards that were really bad. The deck is huge, goes around a 16x40 in ground pool. No way was I going to take all the nails and screws out in order to sand. This was a great way to get a few more years for sure..
  1. ZCI Restore with Epoxy
    Last Post: 03-13-2015, 12:15 AM
  2. Plane Restore
    By Darren Wright in forum Neander Tool Questions and Show & Tell
    Last Post: 03-28-2011, 08:42 PM
  3. WOW Harbor Freight now carries Rustoleum
    Last Post: 02-05-2011, 09:48 PM
  4. Organ Restore
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 08-29-2010, 07:45 PM
  5. Re Decks
    By Rob Keeble in forum Carpentry and Construction
    Last Post: 06-18-2009, 11:44 PM
