Results 1 to 10 of 19
Thread: I'm getting the hang of this !
    Apr 2009
    Outside the beltway
    5,259
    Finished this one up yesterday , I like the way it holds and the sound. Very light weight , The wood has been treated for hardness, Maple. Slate over glass.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Aug 2008
    Reno, Nv
    3,632
    Nice looking call Dave...wood is outstanding!!
    East Freeetown, Massachusetts
    3,021
    Beautiful
    that to purty to take in the field.
    S E Washington State
    3,777
    Beautiful piece of timber. Those things are fun to make. I've made 2 and don't even turkey hunt.
    "We the People ......"
    Apr 2009
    Outside the beltway
    5,259
    Thanks
    My only problem is adhering the piece of wood to the turning board. I use a center screw and then 4 short screws to make sure it holds in place. Is there some other way. Hot glue maybe ?
    Dave not knowing how you turn them makes it kind of hard to suggest the best way. Were I making one I believe I would mount the blank between centers and turn a tenon on the bottom. I The tenon would be at least an inch of not longer would then rough turn the outside to make it wound. Then I would Then I would reverse the blank and put the tenon in a chuck with the live center in the tail stock finish turning the outside leaving enough of the tension to properly support the bland. The I would then begin to hollow out the inside leaving the tail stock in place as long as possible, Back off the tail stock and finish the inside. Part the tenon from the bottom. I never had a vacuum chuck so that would be my approach. I am sure others will chime in. Since the last piece I turned sent me to the Doctor with my alergies I can't do a demo to show you how. I bet Vaughn and some of the more expieranced turners will chime in.
    Apr 2009
    Outside the beltway
    5,259
    Thanks Don. I am turning one now and placing a few drops of the hot glue stick on the otter edges. I placed them to far out and the piece loosened up. Once I found again I remounted it with glue much closer. Now to see if that works.
    Austin, Texas
    1,448
    Dave,
    I don't recognize the thing you are making, but it appears to be slate or something hard mounted in some very pretty wood. Different materials mean that you need a flexible glue. I have become very fond of "DAP Acrylic Latex Caulk plus silicone" in Clear. I comes in a calking tube, starts out white, but dries totally clear, and flexible. Costs a couple dollars per tube, and when wet cleans up easily with water. I wouldn't try it for something like sealing a glass aquarium that has to hold hundreds of pounds of water, but for lesser things, it is great.
    I haven't done a test, but it seems to me to have more holding power than hot melt glue.
    Charlie Plesums, Austin Texas
    Apr 2009
    Outside the beltway
    5,259
    ah Yes Charlie, I use a Acrylic Black Silicone to bed the Slate and the glass under the slate. I use an epoxy once and found out that when playing the call the class cracked LOL
    Don. After remounting the piece I finished the turn and it worked great.
    The inside post are what I mount the glass on. Glass is seated a little over 1/8th " to 3/8s as a sounding board. I'll have to get a video up on the sound. I also use a wood hardener to stabilize the wood.
  1. Hang on, you're in for a ride!
    Last Post: 04-05-2013, 10:14 PM
  2. Lori says I can't hang lights on the new soffits...
    Last Post: 12-15-2012, 02:10 PM
  3. Finally getting the hang ..except..
    By Rob Keeble in forum Lathe Project Showcase
    Last Post: 03-13-2010, 08:06 PM
  4. Getting the hang of it . I think ?
    By Drew Watson in forum Lathe Project Showcase
    Last Post: 01-15-2010, 06:28 PM
