Results 1 to 9 of 9
Thread: Got me a No. 8 jointer
    I picked up a Stanley No.8 joiner and a No. 5 corrugated while we were out antiquing last week. The No. 8 cost me $20 and the No. 5 cost me $7. I want to get new blades for both and was wondering if the Lee Nielsen Blade http://www.lie-nielsen.com/lie-niels...h-plane-blade/ and the chip breaker http://www.lie-nielsen.com/lie-niels...8-chipbreaker/ will fit or do I just need to get the blades from Hock Tools?
    A few pictures of my progress so far. The No. 8 is broken down and dowsed with WD40 to help loosen some parts.
ID:	83254Click image for larger version.
    Here are the missing parts I needed I got off of E bay. The lever cap is for the No.5 and the lateral adjusting lever is for the No. 8.
    I have the No. 8 in the electrolysis bath.
ID:	83257Click image for larger version.
    And the knob and Tote with some sanding and a coat of oil. The rosewood sure smells sweet when you sand it!
    East Freeetown, Massachusetts
    3,019
    That #8 will sure give you a good solid WORKOUT.
    Don't need to go to the gym when you use the #8
    17,471
    alan hock is good but take a look at the chip breaker and iron setup from bmi i think its call at lee valley they are sweet setups but either a LN or Lee valley iron will work well, is that no. 8 a adjustable frog or solid setup? good price on both and nice wood
    Here are a few more pics after taking it out and rubbing it down with a green scotch brite pad and olive oil. I then put it in the cedar wood shavings from my cyclone to rub it down some more and clean off the excess olive oil. The lever cap is in the electrolysis now.
ID:	83261Click image for larger version.
ID:	83262Click image for larger version.
ID:	83263Click image for larger version.
    Larry the frog is adjustable. I have a No. 5 and corrugated No. 6 that I recently cleaned up and put new blades and chip breakers from Hock in those. I tried the Rob Cosman ones from Pinnacle but thet were to thick and I wasn't sure about filing the opening bigger to accommodate them. These looked just as bad as the No. 8 did.
ID:	83265Click image for larger version.
    5,320
    If you're going with the Lie Neilson blade assembly, they make slightly thinner blades that are specifically for the older Stanleys. You might have to call them for more info, since they don't seem to show up on their website any more..
    17,471
    well mr hock does make some fine irons i have a couple of them myslef.. as for filing the throat i can understand your thoughts the hocks dont require that but the pinnacle are a sweet setup if you do decide to do some filing
    Were you talking about the PM-V11 plane blades such as these.
    http://www.leevalley.com/US/Wood/pag...182,43698&ap=1
    Well the No. 8 is all back together. Will do the No. 5 next weekend.
ID:	83267Click image for larger version.
ID:	83268Click image for larger version.
    17,471
    i think they were called pinnacle alan,, rob cosman was rooting for them last i knew.. that sure is some sweet figured wood you got under that no. 8
  1. New (to me) #7 Jointer
    Last Post: 10-30-2009, 02:58 PM
  2. Jointer
    By randy street in forum New Tools
    Last Post: 08-30-2008, 02:10 PM
  3. New/old jointer
    By Frank Fusco in forum Old Iron
    Last Post: 06-06-2008, 01:34 PM
  4. No Big Jointer?
    Last Post: 03-30-2008, 08:41 PM
  5. Which jointer?
    Last Post: 08-07-2007, 09:29 PM
