Results 1 to 5 of 5
Thread: Grease gun pneumatic anyone help
    12,245
    So i fell for buying a air operated grease gun when i was HF last weekend. Now get to try it out and struggling to bleed it.
    Anyone use one of these and got any suggestions that might help. I have done what the instructions say but frankly i am having a hard time understanding how a plunger rod with no end is going to get the grease to move up and push air out. Will try the good old you tube as well see if any tips there. Thanks for reading.
    Yorktown, Virginia
    5,002
    Maybe you got the 1 in a thousand that they forgot to put the plunger on?? Frustrating...did you look for a parts diagram on their web site?
    Jan 2011
    3,798
    ^^^ Agreed....also check inside the housing as well, may be lodged in there....
    12,245
    Thanks guys, well discovered that like many things from Hf you need to disassemble and re assemble and then for some crazy reason they begin to work. Duh
    Turns out there is lots of people have same issue. I found the rubber washer thats supposed to drive the grease out of the cartridge was hanging up on the cardboard edge of the grease tube. When i took it apart i found the plastic piece that drives this rubber had pushed underneath it as it would if one filled the gun from a larger source of grease with no tube. After checking this out and finding other comments i put it back by pushing the tube on the plunger without pulling the plunger lever back all the way. Quiet an effort but it pushed the grease up like its supposed to and got started in the tube. So it does work i think it needs a spacer between the drive washer and the rubber bung that goes in the tube. But for now its working so i aint trying my luck.
    Oct 2009
    Near Gassaway,West Virginia
    105
    I use one a lot. I just use the cartridges. Sometimes it takes a few squirts to get to work, also mine has a air bleeder and I hold the ball valve in with my fingernail or just a plain nail to get rid of the excess air.
    Fred
    steercreekwood.com
  1. Grex pneumatic ROS
    By Tony Falotico in forum Turning Tool Questions and Show & Tell
    Last Post: 09-26-2008, 06:35 PM
  2. Electrolysis or Elbow Grease?
    By Vaughn McMillan in forum Neander Tool Questions and Show & Tell
    Last Post: 04-11-2008, 07:04 PM
  3. Removing grease
    By Nick Clayton in forum Finishing School
    Last Post: 04-12-2007, 04:15 PM
  4. Question about shipping grease.
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 03-11-2007, 03:59 AM
  5. Pneumatic or electric?
    By Chris Mire in forum New Tools
    Last Post: 01-02-2007, 12:05 PM
