Results 1 to 1 of 1
Thread: Table Saw Sled - Small
    When my dad inherited my hybrid tablesaw he also got a couple of sleds. One of them was a small one that I call my 'box sled' although it is used for many other smaller cuts. I am waiting on a finishing stage to cure on a few pieces which will take couple of days so I am free to take care of replacing this little guy. It is about 24" x 16" with about 12" of usable space between the front and rear fences. This makes it a build that can eat up some of my scrap. I usually use hardwoods for the fences but, in the spirit of cleaning out the scrap bin I will use BB ply for all of this.
Name:	Box Sled (0).jpg
    My original "I'm-gonna-make-a-better-version-someday" dado jig built from an old bookcase is still getting used(???). *** [small voice in head] maybe I oughta take care of that between larger projects too ***
Name:	Box Sled (1).jpg
    Anyway, here is the dado jig in use making the stopped dados that will hold the t-track. I also use it to hog out the ZCI strip location.
Name:	Box Sled (2).jpg
ID:	83455 . Click image for larger version.
Name:	Box Sled (3).jpg
    The "fence" pieces in the last pic are just some scrap I set there to make sure I am not wandering too far afield. The overlong ZCI insert is from my 'medium' sled and again is just a prop for the pic. The fences will actually be laminated BB ply pieces that I am waiting for the glue to set up. I just wanted to see the track in place. I will also laminate a dummy block for the blade exit location. Primarily used to cut mitered ends for small boxes it is also handy for any light crosscutting job that requires extra accuracy.
Name:	Box Sled (16).jpg
    When I make the inserts for any jig, I make a bunch as the setup takes the time and not the actual making. Since all my sleds use inserts of a common width I made some extras for the medium sled too. The large sled goes through these the slowest and i still have plenty.
    To drill the through holes in the fence I make sure everything is nice and square. A couterbore allows the washer and nut to set below the top to stay out of the way of any clamping or what-not.
Name:	Box Sled (5).jpg
    And here it is partially assembled. I have to stop for some dinner and will pick this up tomorrow.
Name:	Box Sled (6).jpg
    Ok, so among other things as mentioned, this is one thing it excels at; easy, air-tight, mitered edge boxes.
Name:	Box Sled (17).jpg
    Last edited by glenn bradley; 06-25-2014 at 02:24 AM. Reason: I sometymes cannut spel gud.
  1. Is my table saw sled salvagable?
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 02-11-2011, 02:10 PM
  2. 2 small tables-end grain lamp/end table, small storage coffee table
    Last Post: 06-01-2009, 11:06 PM
  3. Table saw sled - part V
    Last Post: 04-22-2008, 05:28 PM
  4. TAble saw sled - part VI - last...
    Last Post: 04-18-2008, 08:33 PM
  5. Table saw sled - part I
    Last Post: 04-14-2008, 10:14 AM
