Results 1 to 10 of 13
Thread: Wiring question!
    Buse Township MN
    565
    Wiring question!
    Okay folks, I need help. "We" are adding a home office to existing space to free up a bedroom downstairs in case the girl we are adopting EVER comes home from Haiti. I'm adding a 6'x10' closet in the garage for file cabinets and storage. I need to add a switch, light and plug in. I can jump off an existing plug in (only 4 on the 15 amp breaker that do not get used much).
    My first step is to pull the wire to the different boxes. Here is what I think I need to do, I do not want the switch to control the plug, just the light.
    1. wire from exisiting plug to switch box.
    2. Wire from switch box to light fixture.
    3. wire from light fixture to plug.
    Is that it?? Or do I need another wire from the switch to the plug?
    Thanks.
    Every child deserves a family. Adopt. Foster. Get involved.
    13,437
    Sounds about right, but run 3 way wire (14/3 with ground, which has black, white, red, bare copper wires) from the switch box to the light box, use the red wire for the light switch, use the black wire as a carrier to feed the new plug (non-switched).
    East Freeetown, Massachusetts
    3,019
    Some of t he switchs at the store have a wiring diagram on them.
    I would run a 2 wire w/ground to the switch. You only need 2 wires for the switch.
    Nov 2012
    Wapakoneta, OH
    611
    Maybe I'm not following the steps correctly, but it seems if you wire from the light to the plug it will be switched with the light unless you use the 14-3 that Darren mentioned. I think (again, maybe I don't understand) I would change it to this:
    Wire from existing to new plug
    wire from new lug to switch
    wire from switch to light.
    That would eliminate the need for the 14-3 (just use 14-2) and keep the plug energized.
    3,019
    Wiring a switch for a light
    Run a 14-2 wire from the place where the light is mounted to a switch box.
    You will be tying into the black (hot) wire for the switch as shown in the diagram.
Name:	Switch wiring.jpg
    5,319
    Quote Originally Posted by fred hargis View Post
    That's the way I'd do it.. It's the simplest - and easiest - way to do it.
    Buse Township MN
    565
    Thanks guys! I'm using 12-3 wire and trying to minimize the number (and length) of necessary wire runs.
    Nov 2012
    Wapakoneta, OH
    611
    Quote Originally Posted by Barry Stratton View Post
    As would all of us, I suspect. But we don't know how the layout is situated, and sometimes you just have to go a longer route.
    5,319
    Why 12-3? a 15 amp circuit only calls for 14-2, with ground.
    17,470
    jim he used to live in alaska so he probally figures the cold would draw down the amps to the circuit or perhaps that is what he has
  1. 220 V wiring question
    By Allen Bryant in forum Carpentry and Construction
    Last Post: 09-24-2014, 06:41 PM
  2. Hey Sparky...wiring question 4U
    By Ken Cook in forum General Woodworking Q&A
    Last Post: 10-01-2013, 01:56 PM
  3. Cutting blanks on Bandsaw - 220v wiring help / question ?
    Last Post: 11-04-2012, 02:11 AM
  4. New Motor Table saw wiring question
    Last Post: 11-22-2008, 02:45 PM
