Results 1 to 10 of 21
Thread: what would you change?
    17,474
    on this cabinet? the lady wants it to be one door. wont that be to much weight with glass insert ? for the hinges
    Dec 2008
    Santa Claus, In
    4,779
    Even if you go one door, it would still need a rail in the middle to help break it up. Going to take some good hinges for sure. I would also make the sides straight, eliminate the bevel. Would leave the bevel on the front and back pieces, just push the sides in flat, hope that is understandable.
    Just my opinion
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    Thomasville, GA
    5,998
    Does the insert have to be glass? Acrylic would be lighter and wouldn't break. I know, I know - the purist in me wants glass - the practical is another matter. Personally, I prefer the look of two doors, but I'm not the client.
    Bill Arnold
    Dec 2012
    Bedford, NH
    1,683
    Reference:
    http://www.engineeringtoolbox.com/de...ds-d_1265.html
    Density of Common glass = 150-175 lb/ft3 = 0.087-0.101 lb.in3 .
    *3/16” x 27” wide x 36” tall, the weight would be ~ 18 ˝ lbs. (* this would be thick glass)
    If the glass were 1/8” thick, the weight would be ~ 10 ˝ lbs.
    I have a double door on my gun cabinet with each door having a single sheet of glass that is ~1/8” X 13” X 48” & weighs ~ 6 3/4 lbs. Each door has (3) hinges & swing beautifully.
    I don’t think you would have any trouble with (3) good quality hinges. Could even try (4) if that makes you feel more comfortable.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    13,451
    Will have to have some pretty strong joints on those doors. You might go talk with a local glass shop to see what type/thickness they will recommend, then base your design off that. At that size I'd consider some safety glass, which will cost more, but wont have as much of a chance to twist and crack.
    Sep 2007
    Plainwell, Michigan
    4,857
    I like the design Prefer as 2 doors also but your client must want full vision of the contents, beef up the height of the rails and use m & t joints one I would think you would be good
    Nov 2012
    Wapakoneta, OH
    611
    Someone else mentioned it, I would be more worried about the frame joints than the hinges. Might want to make the tenons a lot longer for that along with wider rails/stiiles.
    5,322
    Quote Originally Posted by fred hargis View Post
    Agree with Fred. You might even consider inletting some angle brackets into the door frame corners. You could use iron ones, and 'heat treat' them to get a blued/browned finish so they wouldn't glare out of the finished product.
    OK in the interest of trying to keep the customer happy maybe you could use some sort of a slides instead of hinges. Sherrie has one that the glass is 36" wide. I am attaching a picture to give you an idea. I sits in a hall so it is hard to get a full size picture.
    It would require you to make the door stand proud of the cabinet but I think it would look good.
    5,172
    We can discuss the structural issues and the customer's preferences, but from a business perspective, there is a "I don't want to be sued out of my socks" perspective. I'd explain that your design (2 doors) is structurally sound. One door without some sort of mid-shelf (shelf material?) support presents safety issues that can only be mitigated with safety glass, extra hinges, and a signed waiver of responsibility. There will be extra cost involved. If your customer is good with that, stop thinking about what they will pay, give them the whole picture and true costs. Also explain that from your builder's experience perspective requires you to have them sign a waiver and disclaimer of any future issues with that cabinet. Also tell them they likely can find someone to make as they wish who will not be concerned with the safety issues, but the recourse could have a price to them in injury and/or destruction of treasured items that likely will require court action to try make things right.
    Look at your motto. If in doubt (and you certainly are here), build it stout.
    They will respect you in the morning.
  1. The Oil Change
    Last Post: 12-07-2011, 07:46 PM
  2. Why Change the Name
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 11-06-2010, 03:36 PM
  3. what would yu change?
    Last Post: 03-20-2007, 12:08 AM
  4. Name Change...
    By Marty Walsh in forum Off Topic Discussion
    Last Post: 02-05-2007, 05:06 AM
