Results 1 to 10 of 24
Thread: How to make a grown man CRY and say ALOT of bad words
    4,553
    Well I went to HF and got me some cheap aluminum yardsticks to make some Fret templates and a 1/16" blade from the Griz. Got to work and boy they sure worked great.
ID:	83532Click image for larger version.
    So got busy cutting fret slots and boy it was SWEET done in about an hour and a half with this pile of 84 compared to 2 days doing by hand. OH SO HAPPY RIGHT
    WRONG ........
    The red mark is where the fret slot is supposed to be cut.
    So anybody have any ideas for a design change or enhancement I only have 84 to do.................
    A Turn N Time
    Frog Pond Guitars
    13,462
    Looks like some rosewood tops are in order.
    Jan 2011
    3,798
    Is it just the one fret that's off or are they all off from that point up?
    Edit: if it's that one only, you could widen it a tad, turn it into an 'F' or 'FP' shaped inlay....Viva las Frog Pond
    4,701
    More pointless questions of curiousity than an useful suggestions.
    I guess the main question is why your alignment was off? "Just" layout error or something else?
    Not sure how you're ?clamping? the yardstick to the neck? I could see that allowing creep if not setup right or you let it slide a smidge, I might consider adding a bump stop to the yardstick somehow or something like that to get a positive feel.
    It seems that narrower slots or maybe a pin on the sled to match the slots would allow more precise alignment - not sure if thats needed.
    Can you salvage the necks by planing then thinner and recutting?
    Other than the obvious issue it looks like a bang up idea, nice and simple to use ... once you get it down
    5,175
    So. It wasn't the yardstick. It was a brain pop?
    4,553
    Good idea Ken and yes it is only that one.
    Must of had a senior moment when laying it out the notch was to be cut at 115.7mm and I cut it at 105.7. I thought I had checked it before cutting them all but must have got interrupted.
    Ryan it does have a 1/16 in pin for alignment and I use double stick tap and had no creep they are right where I cut the notches Perfectly cut. EVEN THE WRONG ONE
    A Turn N Time
    Frog Pond Guitars
    4,701
    Quote Originally Posted by Jay Caughron View Post
    Looks closer at picture 1. Nice. Well at least you know the basic idea works
    ...Can you salvage the necks by planing then thinner and recutting?...
    That was my first thought, too. Still a bunch of work, but at least the wood would be saved.
    Jun 2007
    4,944
    Man, I am so sorry!!!
    Dare I say, "Enjoy?"
    JimB
    VOTING MEMBER
    4,553
    Well when I get some cans I am going to try the sanding down and recutting first. They are running the cans I need starting tomorrow. If I had some cans I would have caught the mistake as I had 2 necks fretted up and ready for cans to check it before cutting frets. Just got in a hurry and now will pay the price.
    A Turn N Time
    Frog Pond Guitars
  1. Replies: 7
    Last Post: 10-21-2013, 07:00 PM
  2. you think YOU pay alot for lumber....
    By James Edwards in forum Off Topic Discussion
    Last Post: 11-20-2009, 06:55 PM
  3. drink alot of water and then some!
    Last Post: 07-15-2008, 11:21 PM
  4. Wanna see a grown man cry?????????
    By Jonathan Shively in forum General Woodturning Q&A
    Last Post: 09-08-2007, 01:10 AM
