Results 1 to 1 of 1
Thread: Sealing of Wood - Experiment
    Palm Springs, Ca
    1,169
    Smile Sealing of Wood - Experiment
    Well I can't help myself from constantly experimenting and trying new ideas and techniques. So I decided to embark awhile back on figuring out a way to control the drying process of green rough and/or final turned pc's.
    Background - yep...... there is dishsoap soaking - wood chips - anchor seal - brown bags etc......blah blah blah...............i wanted something simiple and consistent so I tried this stuff called "Turners Choice" because i got a good deal on it and thought I may as well give it a whirl. I read thru the directions on the label and it mentions soaking or submerging the wood for a period of time for best results...................pfffffffffffffffffffffff fffft !!!!!! to much cost and hastle..........................
    Well I started thinking why would I do that ? well because it needs time to penetrate throughly thru the turning - Well I may have a better idea that will accomplish the same thing. So what i did was to turn 2 green wood vessels - 1 from Red Euc and the other 1 from some scrap stark white tree (junk wood laying around). I then sparyed the inside of the turning with the Turners Choice, Then spun the lathe at 1200rpms for a bit say 10mins - then soaked the inside again and using my Typhoon blow gun I blasted the fluid thru the side walls of the vessel as it was spinning (you can see it bleed thru easy) - then wiped own the outside and set them to dry. Red Euc sits inside (swamp cooler on all the time) on my counter where i sit so i can watch it closely to see what happens - The other white junk wood sat out in my garage on a table (So. Calif - 108+ in the garage during the day).
    Results so Far - Pic 1 - White junk one 1 week sitting out it the hot garage - moisture content 6.8% average - wall thickness about 1/8 or a bit thicker - no cracks so far
    Pic 2 - Red Euc -moisture content 9.5 highest reading over multiple areas - 1.75 days - wall thickness 1/8 or a bit thicker - no cracks so far
    Pic 3 - Mesquite - same as above applied finish after 5 days sitting out in the garage
    Pic 4 - All these sitting inside now for almost a a week and half - there was shrinkage because the inserts do not slide in and will need some additional sanding to fit - but there are no cracks - the small cracks in the pic on the one sleeve were there when i used the Turners choice and i wanted to see if the cracking would continue or not - so far I dont think so but if it did it has not been noticeable or only a minor amount - the little bowl had some warping.
    Conclusion - I am not suggesting anyone go buy this stuff and do what I did - I am just posting my experiment results and I am liking what i see so far. The small Mesquite I finished today seemed a bit easier to sand also - If it turns out like im hoping my days of the other methods are numbered..............
    The mixture is half the story - the method of penetration is what seems to be the other half of the sucess so i am hopeful this works.
    As a side note im am also trying another mixture and ill post those results to when I have a chance to try it out.
    Attached Thumbnails Attached Thumbnails 20140626_095534.jpg   20140626_121322.jpg   20140623_212138.jpg   20140626_201429.jpg
  1. An Experiment with Wood Dye
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 04-18-2016, 12:09 AM
  2. Suggestions for sealing exterior painted wood crafts
    By Angela DiFalco in forum General Woodworking Q&A
    Last Post: 11-09-2013, 01:23 AM
  3. Protip: Sealing Wood
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 07-31-2010, 03:43 PM
  4. Wood science experiment
    By Bruce Page in forum General Woodworking Q&A
    Last Post: 08-25-2007, 03:41 PM
  5. Sealing oak in the Bathroom?
    By Matt Dunlap in forum Finishing School
    Last Post: 03-20-2007, 01:43 PM
