Results 1 to 10 of 20
Thread: 8 of 9 for the state fair
    Dec 2008
    falcon heights, minnesota
    5,610
    with the jardiniere being project 7 of 9 for the fair, i guess this one is number 8. it is a side table of a different design. it will stand 2 ft high, the top will be 24" in diameter, and the bottom shelf is 12" in diameter. i managed to set aside enough of the small offcuts from the chairs for the smaller legs, and the lower shelf. all i need get now is the red oak for the top and large legs.
    Attached Thumbnails Attached Thumbnails 001 2014 fair table.jpg   002 small shelf.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,610
    slight change in plans, going with white oak, and finishing the same as the clock and jardiniere. couldn't find enough shorts in red oak, and went with everything in white oak. couldn't beat the price.
    9,077
    Quote Originally Posted by Dan Noren View Post
    I like the design. Its like a cool twist on a Limbert-like style. State Fair hold on to your hats.
    Dec 2008
    5,610
    after hitting the jardiniere parts with sealcoat, took a pic of the new white oak boards.
    Dec 2008
    5,610
    spent a couple of hours today planing all of the boards to thickness. tomorrow is the day for laying out of parts.
    Attached Thumbnails Attached Thumbnails 004 new boards planed to thickness.jpg
    Dec 2008
    5,610
    now that the jardiniere is done, and the boards planed to thickness, it was time to start laying out the parts. started in with the small shelf. cut to size and glued up. more work on the big legs and the top tomorrow.
    Dec 2008
    5,610
    a bit more done today. got the top blank glued up, and the leg blanks ready. the odd part on the legs are for the shelf support (you'll see once i cut the legs to shape).
    Attached Thumbnails Attached Thumbnails 006 top glued up and in clamps.jpg   007 legs glued up and ready to be cut.jpg
    Dec 2008
    5,610
    even more done today. laid out the leg pattern on the blanks, laid out the circle for the small shelf. rough cut the leg blanks and small shelf, then sanded to lines. then it got even more fun, rigged up the router to the circle cutting jig and cut the circle for the top. then got a pic of pop spraying miracle gro on his lilacs. then the real fun happened, did the first test set up of the table and said wow....
    Attached Thumbnails Attached Thumbnails 008 leg shape laid out on blanks.jpg   009 small shelf laid out.jpg   010 small shelf rough cut.jpg   011 legs rough cut.jpg   012 top cut.jpg
    013 small shelf sanded to line.jpg   014 legs sanded to lines.jpg   pop spraying.jpg   015 first test set up.jpg
    Jan 2011
    3,798
    That's looking great Dan
    12,262
    I agree with Ken THAT is looking real good.
    Very clever idea on the legs Dan
  1. state fair results are in!!!!
    Last Post: 09-05-2014, 11:48 AM
  2. item 5 of 9 for the state fair
    Last Post: 08-10-2014, 07:36 PM
  3. state fair results
    Last Post: 08-22-2013, 09:48 PM
  4. state fair results
    Last Post: 09-09-2011, 01:08 AM
  5. second of 3 state fair projects
    Last Post: 07-07-2011, 04:37 AM
