Results 1 to 7 of 7
Thread: A Staining Question.
    S E Washington State
    3,777
    There is a gentleman on the Scroll Saw Workshop Forum that is a master scroller/scroll saw pattern maker. He is asking how a person could make a gray stain, that would mostly be used on baltic birch plywood, for scrolled animal pictures, such as deer, raccoons etc. Would be good if it was a simple mixture he could easily mix up. Any suggestions?
    "We the People ......"
    17,470
    havnt done it paul, but possibly mixing some white with a black dye or stain to get the shade of gray he is after.
    5,167
    Rusty water often leaves a gray stain. Cheap to try a sample. Iron oxide. Sweep up the grinder debris and add water.
    3,777
    I tried the steel wool and vinegar and I thought it looked pretty good for what he wants. On BB it gave a grayish color with sorta a brown tone to it. Ought be go for scroll saw animals.
    Roanoke, Illinois
    212
    Use transit dyes and mix in alcohol to reduce grain raising.
    Either you like bacon or you are wrong.
    3,777
    Thanks for the responses, I will pass on the suggestions.
    May 2011
    So. Florida
    268
    It would take some experimenting, and ratio checks. Start with about 60-75% mineral spirits, and about 15% BLO. For color use an oil base black and white paint. Start with the white and gradually add in black until the mix produces the shade of gray you want. When experimenting with samples, once the stain looks close on the sample, when dry, apply the topcoat in your finishing regimen. That will change the way the sample will look. The above ratios are approximate.
  1. edging and staining
    Last Post: 03-07-2014, 07:08 PM
  2. Staining Red Oak ?
    By Wayne Ashing in forum Finishing School
    Last Post: 09-22-2009, 12:27 AM
  3. Staining Poplar
    By Tony Maio in forum Finishing School
    Last Post: 03-08-2009, 11:18 PM
  4. Glue-up after staining
    By Aaron Beaver in forum Finishing School
    Last Post: 11-27-2007, 05:36 PM
  5. Staining Cabinets....
    By Corey Hallagan in forum Finishing School
    Last Post: 11-28-2006, 06:05 PM
