I am finally back to work on the Great Pumpkin. Hoping it will make some chips in the next few weeks. The list of things-to-do is actually very short. The motor has been the main hold up. That and getting 3 phase power in the shop. The is is done and sitting in place.. well sort of. Gives me a chance to eye-ball it for a few days to decide how I want to mount it.
Tonight, despite the fact this heat is just wearing me out, I made myself go to the Lab and do some work. I decided to play with paper dolls and try to make a blade guard. Since I am keeping the square head the guard is not an option, it is a must!
I made a couple of cardboard dollies and found one I liked. So I graduated to luan dollies.
This one looks pretty promising. I have a hole in the table that I assume was for a pressure bar when doing moldings? It's in an excellent place for the guard and even had a thread hole for a set screw.
I have a small gap present when I run a narrow strip through there. I may try one more and try making the radius larger and see if that helps close that gap. Even so, it's pretty small and wouldn't be easy to stick a finger in there. And I plan on using push blocks all the time!
I didn't allow for a method of holding the guard in place. That will be either an extension spring or a counter weight. I am giving serious consideration to a counter weight just because they are old school (and simple). But the spring is simple and nothing to go wrong with it except if it breaks.
Jeff
