Results 1 to 10 of 12
Thread: Air hose connections,, irratating!!!
    17,472
    i just finished a job that i needed all my air hose to get the job done when i started i had one hose that the female end would leak once you hooked it up.. but half way threw the job the other one is doing the same thing.. yet i got 2 other old rubber ones that are just fine.. do i need to change out the ends or is there a fix for them?
    5,172
    Seems to me there is a rubber o-ring in them. Maybe it has dried out? Try soak in something to soften the rubber? Don'y know what though.
    Dec 2012
    Bedford, NH
    1,683
    Only questions at this point.
    1. I'm assuming you're referring to quick connect/disconnect fittings???
    2. How long have you used the socket fittings?
    3. Are they aluminum, brass or stainless?
    4. Have you checked them for wear, both the socket & plug fittings?
    5. Have you tried cleaning them?
    6. Once they start to leak, can you "wiggle" the fitting & stop the leak?
    7. Have you disassembled the socket fitting to check the condition of the "internals", i.e. rubber o-ring/seals?
    8. The fact that they don't leak until hooked up to the plug fitting might suggest wear on the socket or perhaps even the plug fitting???
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Larry I just went out to the shop and looked at some of mine and carol is correct there is an small O ring on the inside of the female connector that the end of the male connector presses against. I would try replaceing that O ring of you can get the old one out.
    17,472
    well i was wondering if that was a o ring or just a washer that it seats next to... will see if i can dismantle one tomorrow.. dont see how i can, they just spin around on them selves? and to pul the old one out threw the hole would be a feat in itself let alone pushing one back in/// Al the female fitting is the one leaking not when plugged into gun just when its on the end of the line of air
    5,172
    Mine looks different then that. hmmm the one on my system the O ring is smaller and is deeper into the fitting. Like where the end of the make connector seats.
    Independence, Kentucky
    1,354
    Sounds like the plunger at the back is what is leaking, if it leaks when not connected. Did you try pushing a nail or pin of some sort down there a couple of times with pressure on the hose? Sometimes there is some junk holding the plunger off the seal just a little Push and release a couple of times to see if it will seal.
    17,472
    i agree with don mine is alot deeper and i did try your idea charles, used high pressure from the shop to try and b;low out any junk that might be in the way it acts like it doesnt line up well and the spring might be week to hold in the right place??? can try the o ring trick and se what happens then..
    5,320
    If you're not spraying paint, try a drop of oil into the female fitting, around the O-ring, before use.
  1. Electrical connections on machine motors
    By Rob Keeble in forum Safety Tips
    Last Post: 05-09-2014, 10:54 PM
  2. Connections - Long Range Rifle Shooting - Woodworking - Did You Know
    By Pete Simmons in forum Off Topic Discussion
    Last Post: 05-21-2013, 01:06 AM
  3. Strange connections @ school
    Last Post: 11-05-2010, 10:48 PM
  4. Computer to TV connections
    Last Post: 10-25-2010, 02:18 PM
  5. Bed makers connections
    Last Post: 11-15-2008, 01:46 AM
