Results 1 to 5 of 5
Thread: Locating Details
    Locating Details
    I am new to SU and one thing that I have struggled with is placing details. For example I'll draw a wood part (I found an use the Box plugin) on the origin and then make this a component. Now if I want to add say a hole at some position on the face I first use the tape tool to draw construction lines one parallel to the bottom edge at a distance I type in the second line is parallel to one end at a specified distance. Now I am ready to add the circle at the intersection of the 2 lines. Not difficult but seems to be a lot of steps. Am I missing an easier way?
    By the way I change my copy of Box so it asks for length, width, and thickness which is more natural for wood working. Also I found that I could enter 3/4 and get 0.750 thickness.
    SE Minnesota
    2,550
    Keith, I use your method of locating details pretty much as you have described. Guides (formerly Construction lines) are pretty quick and easy to use. I have set up E as a shorcut for Edite/Delete Guides because drawings can get cluttered with a lot of guides drawn.
    Good on you to use the Box script. I generally don't bother because it is fast enough for me to use Push/Pull. The cool thing is there is more than one way to handle things like this.
    SE Minnesota
    2,550
    You could set a Guide (Construction) point by entering the point's relative coordinates from a corner. Select the Tape measure tool, click on the reference corner and drag in the general direction of the points final location. Type the relative coordinates as <x,y,z>, Enter. This would get you the point for the center of the hole with a single action from the Tape Measure tool. I find it quicker to drag a second guide line because I don't have to let go of the mouse for it.
    Dave I tried the tape tool and entering the coordinates it seems to only take one entry the length of the diagional. I'll stick with the guide lines as I understand that method and it goes back to my drawing board days I used that method with the drafting machine.
    SE Minnesota
    2,550
    Keith, did you use the < and > to enter the coordinates? Those symbols tell SU that you are entering a coordinate relative to the point you click on with the Tape Measure tool. If you enclosed the coordinates in square brackets [ ]you get absolute coordinates.
    I do think just drawing the guides is quicker.
  1. Brent's New Flatbed - Details Coming
    By Sharon Korn in forum Off Topic Discussion
    Last Post: 12-13-2011, 03:00 PM
  2. Help Locating Casadei User Manuals
    By Pohgunn Ooi in forum Old Iron
    Last Post: 09-20-2010, 11:29 PM
  3. Small Oak Bookcase, with Mission inspired details
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 02-05-2009, 09:03 PM
  4. A few house details
    By John Dow in forum Carpentry and Construction
    Last Post: 08-19-2007, 04:56 PM
