Results 1 to 10 of 14
Thread: broke my bandsaw...
    London, Ontario
    3,383
    broke my bandsaw...
    Just venting...
    Tried to change the blade on my 14" bandsaw tonight. However the tension adjusting wheel would not turn very easily.
    I kept working and working at it, and soon had the wheel off in my hands!! Part of the tension adjusting shaft had just sheered off inside the handle!
    I was stymied... I'm left with a smooth shaft.
    I resorted to the old faithful of rough tools. Yes: vice grips.
    Even then the thing was just not turning. I finally was able to get the blade off, so that left the wheel and tension thing loose, but the shaft was still stuck. I sprayed in some WD-40 and left it to soak. Eventually I dismounted the upper wheel. This left me enough room that I could lift the upper wheel sliding bracket enough that the nut holding the tension adjusting rod and tension spring dropped out the bottom so I could get an actual wrench on the nut and get it off. Still was fighting me for a few turns before it finally let go and spun off.
    The shaft is ruined -- some of the threads stripped out (green arrow). The problem seemed to be that the top part of the shaft was just totally gummed up which prevented it from turning freely (that is indicated with the red arrow, though it's since been wiped off).
    Fortunately we've got a pretty good Bandsaw vendor here in Ontario that stocks replacement parts (R+D Bandsaws, == www.tufftooth.com)
    I'm not sure what I could have done to prevent this. This part of the shaft is totally contained inside the upper wheel bracket, as well as the tension spring. Tiny bits of sawdust had gotten in there to gum up the threads, but there is not really any easy way for me to get in there to clean it out. Of course, I should have been releasing the tension more often, then maybe it would have kept it clearer. (I admit, I almost never release the tension on the saw.)
    Yorktown, Virginia
    5,022
    Sorry that happened, Art. You are lucky to have parts available locally for a quick fix. Now you know the mean time between failure...how many years did you get out of that part??
    Feb 2012
    2,749
    Glad you were able to get the parts, Art. I use R&D blades, and if I weren't so lazy, I'd pick up some cool blocks and other stuff, too. The lady in their office is very nice, too.
    Cheers,
    Roger
    new york city burbs
    10,188
    e replacement parts, or something like that will have your parts if you cant get them from the local guy.
    I replaced a gear that cracked in my mustard band saw and it ran better than the original part. all for 3.00
    good luck on the fix, if you were closer, Id let you borrow mine I wont be using it for a few months.
    Human Test Dummy
    London, Ontario
    3,383
    Hmm, I think I wrote carelessly... I don't have the parts YET, I just plan to call them tomorrow.
    London, Ontario
    3,383
    I'd have to dig through my records, but I'm thinking I got a good 12 or more years out of it.
    12,264
    Art while you at it replace that coil spring with the newer version i think LV has them
    http://www.leevalley.com/en/wood/pag...36,56060,56055
    London, Ontario
    3,383
    Great Minds, Rob...
    I ordered the replacement rod/handle AND new spring from R+D Bandsaws this morning. While I was at it I also ordered a 3/4" resaw blade for my bigger BS, since their summer sale price is nearly half off...
    12,264
    Art just a word of caution i have had blades from R&D that were not cut to the correct length. Was not impressed never mind the quality of joint so do look it over before you use it.
    I am going to order a bunch from Vaughns reference vendor (Ellis) and ship to my Niagara adress you close enough to border that u could do the same thing in Sarnia there must be a similar warehouse setup in Port Huron. In the case of bandsaw blades I feel if they priced better one would change them more often and have better results.
    London, Ontario
    3,383
    I wonder if you got a bum blade, Rob. R+D has been in business for ages. I've been visiting them at the local woodshows for the past fourteen years. The owner usually gives tune-up talks and demos also, doing a good job of educating people. I don't buy a lot of stuff from them, but have not had any issues myself. The blade I ordered is a "Woodslicer", which is well known in the US (I think?) but new here in Canada. And yeah, I now sound like a shill for R+D!
  1. Broke in the blasting cabinet
    Last Post: 06-01-2016, 03:19 AM
  2. Broke My Vessel
    Last Post: 02-15-2010, 07:14 PM
  3. How did THAT happen!? (broke CMS fence)
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 02-15-2009, 01:17 PM
  4. I broke my teeth on the table saw
    Last Post: 12-01-2008, 04:09 AM
  5. Broke Back Deer Camp
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 11-16-2007, 12:36 AM
