Results 1 to 10 of 13
Thread: Tools, after the Grinder - Then What?
    Jun 2007
    4,944
    Hi All,
    My son who knows nothing about turning is trying to help me with my tool sharpening. As a matter of fact, he just pushed me out of the way and is now typing this . . .
    For those of you who use a Wolverine or shop made version thereof, once you do this:
    Attachment 83835
    or this:
    Attachment 83836
    What is your next step to sharpen and then hone the tool?
    Dad has a Jet clone of the Tormek. The geometry of the tool holders for the Jet is different than that of the Wolverine (or shop made version thereof).
    Attachment 83837 . Attachment 83838
    So speak oh vault of knowledge . . . what do-est thou?
    VOTING MEMBER
    Feb 2012
    2,749
    I have been using a cloth wheel loaded with polishing compound. It works well, but I've just gone to a hard felt wheel loaded with polishing compound. It also seems to work well. For my skew I use my waterstones.
    I'd be interested to know what angles and dimensions you used to make those jigsfor different tools.
    Cheers,
    Roger
    Aug 2008
    Reno, Nv
    3,632
    Honing is hit and miss for many. Well worth it on a skew, but as Dale Nish once said..."see that burr on this gouge?" He made one pass on a bowl blank..."Now it's gone." Being one of the best turners in the world...that got my attention. If you use the angle guide from Tormek (the proper term escapes me at the moment) you can duplicate the angle from the Wolverine set-up on the Grizzly.
    Yorktown, Virginia
    5,015
    For me, there is no next step. After the Wolverine, the tool is ready to cut. I use a diamond card hone to refresh the edge in between sharpenings.
    Jun 2007
    4,944
    thanks Ted. Is this true when turning dry hardwoods?
    VOTING MEMBER
    30,017
    I'll echo Jim and Ted...although I hone my skews, I've not seen a noticeable improvement in the performance when honing a gouge. As for using the dry grinder vs. using the wet...I'd say pick one, but not both. Either will work fine, but there's no real benefit from using both. As you noticed, the jig geometry does not match up exactly, and it never really will. The vast majority of turners do just fine grinding their gouges with a 120 grit dry wheel. I prefer using my 400 grit wet wheel, but that's mostly because my Tormek jig is easier to set up and the wet grinding removes minimal steel. But if you were to hand me two gouges - one sharpened on a 120 grit dry wheel and the other sharpened on a 400 grit wet wheel - I doubt I could tell one from the other, especially after cutting for a minute or two.
    And this applies to both wet and dry wood, in my opinion. ;-)
    4,699
    Quote Originally Posted by Jim C Bradley View Post
    For me - yep, although you might have to go back to the grinder a smidge more often than you would with green wood. The one exception is the skew and that's largely because I don't really like the shape of it off of the grinder, the hollow grind imho makes it "catchier" and so a somewhat flatter or even rounder edge is a bit more forgiving so I use a stone for that.
    That last shot of the gouge tip - is that a spindle detail gouge? if so.. I guess its ok, otoh if its a bowl gouge you'll want to "swing" it side to side more so it has more "wings" and a somewhat rounder nose or it'll be a bit funny to use.
    Apr 2008
    Independence MO
    561
    On another forum, I read how they recommend the use of the dry grinder, if changing profiles/making a custom gouge, and then finishing it off with the Tormek. This was simply for speed and making a wheel last.
    That said, multiple things I have read said the Tormek jigs work on the Jet. I know they work on the Grizzly (dad has that), and I have the Tormek (share the jigs). Tormek does have a jig to use their jigs on a dry grinder (parts of that came with my system).
    Yorktown, Virginia
    5,015
    As others have said, wet or dry wood doesn't make much difference. I also will hone my skews with the fine diamond card, but I don't go crazy with it.
    I didn't notice the profile on that last photo and agree it seems to want a little more 'wing', even for a spindle gouge.
    30,017
    Quote Originally Posted by Randal Stevenson View Post
    I agree about using the dry grinder for changing profiles or other cases where you need to remove more than just a little metal. I also have the pieces to use the Tormek jigs on my dry grinder, but still haven't gotten around to building the proper base and getting the other parts set up.
  1. New grinder
    By Don McFarland in forum General Woodturning Q&A
    Last Post: 05-04-2013, 09:35 AM
  2. Tools for sale I have more tools than room
    By Jack Holt in forum Classified Ads
    Last Post: 12-14-2012, 08:44 PM
  3. New Grinder ...not
    Last Post: 02-16-2012, 01:39 AM
  4. DELTA WET-DRY GRINDER-PLUS
    By edward alexander in forum Old Ads
    Last Post: 08-22-2009, 03:14 PM
  5. Grinder wheel dressing tools
    Last Post: 05-27-2009, 08:52 PM
