Results 1 to 7 of 7
Thread: Those touch up slip stones.....
    Nov 2012
    Wapakoneta, OH
    610
    I was reading the thread about what next after grinding, and had a question. Not wanting to hi jack that thread...I've started a new one. I saw Alan Lacer on Yoder's woodturning show crow about his diamond slip stone, only to find out they are north of $80. The total doesn't make me wince as much as it just seems overpriced. Anyway, I see Craft Supplies now offers a similar stone (not really, it's a piece of sheet metal), but it's CBN. It's also around $40. I'm thinking it may be as good for touch up's as the Lacer stome...what's other opinions?
    Roanoke, Illinois
    212
    I have one of Lacers hones. Been using it for 14 years. I use it a lot. I haven't noticed any wear. I would say that I got my moneys worth. D-way tool also sells a CBN hone. His are $68.
    Either you like bacon or you are wrong.
    Austin, Texas
    1,448
    I use the DMT Diamond 3x8 inch plates for regular sharpening, but for touch up I use a mini set like this - $27.50 for three grits
    http://www.woodcraft.com/Product/200...-hone-Kit.aspx
    Charlie Plesums, Austin Texas
    Nov 2012
    Wapakoneta, OH
    610
    Charlie, I have some similar to those but they don't seem to be that useful for the inside of the gouges....or maybe I don't need to clean the inside of the curves up?
    Austin, Texas
    1,448
    Quote Originally Posted by fred hargis View Post
    The burr that builds inside from grinding the outside will come off practically instantly when you start using the gouge on the lathe. I don't worry about it at all. I rarely hone the outside of my bowl gouge (most used tool) beyond what comes off the wheel. I spend the 30 seconds starting the grinder and resharpening it every 10 minutes of use (not scientific measure, just estimate)
    I do use the small diamond set regularly to hone my router bits.
    S E Washington State
    3,777
    I have one from D-Way Tools also. Have use it a lot and no visible wear. I also have a couple of his beading tools, I love them and if I had the money, I'd have them all.
    "We the People ......"
    30,002
    I agree with Charlie. I have a Tormek with the special leather wheel with gouge profiles on it, and I've not seen any real tangible improvement from honing the burr off the inside of a bowl gouge. Same with honing the outside of the gouge...no noticeable improvement beyond the freshly-sharpened gouge.
    I sharpen (or switch to another sharp gouge) whenever I notice that I'm having to force the tool into the cut. The frequency varies a lot, depending on what wood I'm turning.
  1. Tread grippers/non slip ideas
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 04-20-2016, 12:16 AM
  2. My new Arkansas slip stones have arrived
    By Rob Keeble in forum Carving
    Last Post: 03-11-2016, 08:17 PM
  3. Slip bark whistles - its getting on that time of year again
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 03-30-2015, 11:53 PM
  4. non slip mat problem!!!
    Last Post: 03-26-2013, 11:17 PM
  5. water stones
    By Bart Leetch in forum Neander Tool Questions and Show & Tell
    Last Post: 08-28-2010, 03:27 PM
