Results 1 to 10 of 10
Thread: Hay/straw shed design
    Hi, this is my first post. I have a project I need to build on my own. I need help with the design. I need a storage shed for 4 round bales of hay or straw. I would like to have two bales in back and two in front. I would like the two in front to sit on a lazy susan so they could spin as I pull the layers of hay off of the bale. One bale weighs 1000 pounds. Do you think this is feasible?
    Yorktown, Virginia
    5,011
    Denise,
    Welcome to the family. Anything is feasible. I bet any number of clever people on here could come up with something that would work. Do you have welding skills?
    SE Minnesota
    2,526
    What are the dimensions of your round bales?
    4,698
    Welcome aboard Denise! Its a good crew here.
    The lazy susan idea not really no. Possible yes but not feasible. There are really two problems with the idea, first you'd need to build a pretty darn hefty piece of kit to have a round bale rotate easily on it. More problematic imho is that the mechanism would pretty quickly get gummed up with hay.
    The simplest solution is to just make the shed big enough you can get around the bale a little. You don't have to have a huge amount of clearance on the back because you can push/pull the hay from the sides.
    Over engineering it just a little you could lay a bale on its side and put a spear (could be made from a sturdy pipe) through the center and unroll it that way. Of course you'd have to have some sort of level setup to hoist the bale up and honestly it still wouldn't turn very well because it would be unbalanced 90+% of the time (from what I've seen).
    Note that old pallets work quite well to keep round bales off of the ground so keep your eyes open for a couple of those - you ought to be able to get 4 for free or close if you aren't in a hurry..
    Yorktown, Virginia
    5,011
    What equipment do you use to move the bales with?
    Thank you for the input. The bales could be 5' heigh by 4 or 5 round. No equipment to move them. We roll them. I think Ryan Mooney is right, I just need to put them on pallets with enough room to walk around and pull hay off roll.
    Thanks again.
    Dec 2008
    Santa Claus, In
    4,779
    Don't forget a good tarp to keep them dry.
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    13,438
    Welcome to the forum Denise. There are some university sites that offer free plans for farm buildings and equipment. Here is one...
    http://bioengr.ag.utk.edu/extension/...97.htm#General Barn and Utility Shed Plans
    As for moving large bales like that, my dad used to build some hay haulers years ago that used a come-along/winch, similar to the one below, that could allow a small tractor or car to move the bales around.
    3,134
    You would have to decide what kind of platform to build, but I know an easy way to make it spin. I suggested how to & helped build a merry-go-round once using a front hub assembly & spindle from a car. Now days I would use a straight axle & spindle from an old trailer. We used what we already had. Put a square tube set into concrete in the floor to receive a shaft to which the spindle is attached with the hub pointed up & use the studs to mount your platform. You'll need to decide what the platform consists of it will want to be set so the top is flush with the floor.
    This system made a very nice merry-go-round.
    Dec 2012
    Bedford, NH
    1,683
    If your intent is to find an easy way to remove "sections" (not necessarily layers) of hay from the bale, a chain saw might work. Sit the bale on end & just cut out what you need, as you need it - might be a bit dusty & need to be careful about fires. Crazy huh? I'm having one of those days.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
  1. Last Straw..
    Last Post: 04-07-2012, 10:21 PM
  2. Squigly Straw Maker?
    Last Post: 09-25-2011, 11:29 AM
  3. Steel shed vs wood shed
    Last Post: 01-04-2011, 02:37 PM
  4. I need a shed.
    Last Post: 05-12-2010, 09:22 PM
  5. Our straw house
    By John Dow in forum Carpentry and Construction
    Last Post: 03-10-2007, 08:28 PM
