Results 1 to 7 of 7
Thread: Stain then assemble or assemble then stain?
    I'm FINALLY back in the shop this week, working on the adirondack chairs I promised months ago.
    Everything is cut, surfaced, routed, and prepped. Last night I drilled and countersunk all my holes. I am ready for assembly. OR AM I?
    It's made of plain old PT pine. I will be staining w/ a redwood color deck stain.
    Should I stain it BEFORE or AFTER assembly? My main concern is that if I stain AFTER assembly, I will miss many surfaces as they are affixed to other surfaces and/or impossible to get to.
    I don't have a sprayer, I will be brushing.
    Thoughts?
    30,017
    Personally, I'd stain it before assembly, knowing that I might have to do a little touch-up afterward.
    5,321
    Since it's an Adirondack, I'm assuming there are no glue joints involved. So... stain it - and even varnish it - if that's what you want - before assembly, then go back and touch up any screw holes, etc. after assembly.
    Thomasville, GA
    5,994
    Yep - stain first. I've done the same on cabinets I glued together by taping the points to be glued before applying stain and sealer.
    Bill Arnold
    Sound like a consensus! Stain then assemble. Staining should be done this evening, then...
    I frequently stain parts prior to assembly. Primarily areas that will be hard to reach or that are prone to application issues. I may only pre-finish certain areas. Once assembled, I finish the piece.
    Apr 2009
    Outside the beltway
    5,255
    I agree Staind first then everything is sealed
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  1. Stain bleed out..
    Last Post: 02-25-2015, 11:46 PM
  2. First time using red oak, how do i stain?
    By Zach Meissner in forum Finishing School
    Last Post: 06-05-2014, 04:16 PM
  3. Min-Wax gel stain
    Last Post: 10-20-2012, 04:41 AM
  4. Gel Stain ?
    By Bob Gibson in forum Finishing School
    Last Post: 10-14-2010, 02:10 PM
  5. stain VRS dye?
    Last Post: 12-23-2009, 08:37 PM
