Results 1 to 10 of 13
Thread: Dust Deputy - Shop Vac Modification
    My shop vac gets a fair amount of use. Aside from general clean up it provides the suction source for my ROS, Router, Jigsaw, etc. One of the first things I did was get a CleanStream filter which made cleaning the filter so much easier. The I added a Dust Deputy as an upgrade from my 5 gallon bucket separator lid; amazing improvement. I can empty the DD's 5 gallon bucket a dozen times or more and still only get a tablespoon or so of waste in the vac's main container. The only problem that still plagued me was that now that I hardly ever had to access the 16 gallon vac bin, it was still part of the system.
    I had been percolating on an idea (fed by numerous others who have done the same thing) and I had one of those "moments" yesterday. I call these my "that's it" moments because something that was an observation turns into an inconvenience, then blossoms into an annoyance and suddenly . . . without warning . . . will become INTOLERABLE! A switch flips in my brain and a very large voice shouts "THAT's IT . . . I have had it!".
    I got up a bit early this morning and built this proto type. It was too early for the DC and larger tools so the scroll saw got put to use:
Name:	Ridgid Vac Mad v1 (1).jpg
ID:	84179 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (2).jpg
    This prototype is built out of scrap particle board that LOML brings me from her work. They are used as pallet "stack" dividers in the trucks that come and go. The drivers leave them for here as their loads get smaller and smaller during the runs. The material is pretty questionable so I seat a t-nut with a clamp as a hammer blow would probably destroy the panel.
Name:	Ridgid Vac Mad v1 (3).jpg
ID:	84181 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (4).jpg
    There is a chamber within a chamber just like in the original vacuum. A chamber for the blower pulls are from a second chamber through the filter. The filter chamber has the ingress from the Dust Deputy.
Name:	Ridgid Vac Mad v1 (5).jpg
ID:	84183 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (6).jpg
ID:	84184 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (7).jpg
    A hole cutter is used to make the hose connection hole.
Name:	Ridgid Vac Mad v1 (9).jpg
ID:	84188 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (10).jpg
    cont'd . . . . .
    Here's a shot with the top still off showing the internal chamber to chamber path. The open side facing you is actually the top and will have the Dust Deputy host connection.
Name:	Ridgid Vac Mad v1 (8).jpg
    A test run proved very successful. I was after the smallest footprint that would not restrict the blowers airflow path; I somehow got that part right . . . or at least not negatively impactive . I picked up a quart of fine dust, plane shavings and random junk. All but one of the shavings ended up in the Dust Deputy bucket. The shaving made it to the filter chamber which is emptied easy enough for the 2 or 3 times a year i will have to clean it and the filter.
    The whole rig is now about the size of the original vacuum all by itself.
Name:	Ridgid Vac Mad v1 (12).jpg
ID:	84193 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (11).jpg
ID:	84192 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (13).jpg
    Obviously this install is still just in the testing stages. I am already pretty much sold and the vac that serves my small bandsaw, DP and scrallsaw area could use the same treatment. The real benefit of this specific vac mod is that now I can relocate my compressor and vac system so my drum sander can get the heck outta in front of my hand tool area. Maybe I will finally build that wall hanging tool cabinet I have wanted for so long.
    10,604
    Really cool Your ideas and improvements are always fascinating
    I've had my dust deputy on what I think is the same vac as yours for at least 2 years. When I empty the dd's bucket I always check the shop vacs filter and tub. I've never had to empty the tub or change the filter. There is not much more than a fine dusting in the tub.
    I use it all the time on my ros, small router, and general clean up as well.
    It's the greatest invention ever
    Its amazing how devil-may-care you can be when you are designing things on the fly. It also helps to be using material that was already in the trash on its way out . We all have specific needs based on floor space and shop configuration but, for my latest version of this thing, the bucket needs to stand on the floor. May I present the star-spangled, dopplegangled, new-fangled bucket retention system:
Name:	Ridgid Vac Mad v1 (14).jpg
ID:	84204 . Click image for larger version.
Name:	Ridgid Vac Mad v1 (15).jpg
    Keeps me from dragging the rig out of its place while in use. After the silly-cone gaskets cure I will reassemble and that should be that.
    So essentially I went from this:
    To this (the box to the right of the vac covers a small compressor and is not part of the vac setup):
Name:	Ridgid Vac Mad v1 (16).jpg
    13,439
    That is a nice compact looking setup Glenn. Been considering the DD, but have yet to drop the dime for it, I think you've pushed me over the edge.
    30,014
    Great mod, Glenn. When I got my last shop vac, Home Depot didn't have any of the Rigid blower/vac units in stock, so I went with a non-blower Shop Vac model. Not sure if I can build a similar enclosure, but if I can., I'd sure like to.
    ...Been considering the DD, but have yet to drop the dime for it, I think you've pushed me over the edge.
    Every once in a while, a new tool comes along and when you get it, you say "Man, how did I live without this?" The Dust Deputy is one of those.
    I have a second vac which is not a blower style. I plan to build one of these for it as well so I will take one for the team and share my success or failure ;-) The main limiting factor is being able to get the motor housing 'module' small enough to make it worth doing.
    Dec 2008
    Santa Claus, In
    4,779
    I really like it Glenn, but particle board? Really? I was figuring some thing like cherry with a touch of Greene & Greene
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    30,014
    Quote Originally Posted by Steve Southwood View Post
    This is just the prototype for proof of concept.
    Jun 2007
    4,944
    Besides that, the particle board is way past being Green let alone Greene & Green.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Dust Deputy vs. HF Dust Collector
    Last Post: 06-29-2015, 01:54 PM
  2. Shop Vac / Dust Deputy - Status Report
    Last Post: 12-09-2014, 04:26 AM
  3. New dust deputy
    Last Post: 12-12-2011, 10:49 PM
  4. Dust Deputy
    Last Post: 08-07-2011, 01:17 PM
  5. DIY Dust Deputy® for only $39.00
    By Rennie Heuer in forum Hot Deals
    Last Post: 03-22-2011, 10:15 AM
