Results 1 to 10 of 24
Thread: Parting is such sweet sorrow...
    Feb 2012
    2,746
    Red face Parting is such sweet sorrow...
    Today I turned a 3" pepper or salt shaker in the end of a 15" piece of Butternut. Everything went marvellously until I went to part it off. I had mismeasured the depth of the hole for the salt container, and cut into it with the parting tool, with dramatic effect. The shaker bounced off my shoulder and disappeared, and the long part of the workpiece scurried under the frame of the lathe and hid in a corner. The shaker itself cracked and a chunk came off the base, and it fell, appropriately, into my firewood box.
    Now, I know the mistake I made with the measurement, and I won't do it again. I've parted off a number of things in my short turning life, but I'm wondering with a piece like this, which has a long straight span beneath the piece, couldn't I just take it off the lathe when I am finished shaping the end piece, put it into my table saw and cut it off at right angles? This is what I did to remove the stub from the long part, and it is perfectly at right angles. It would have saved me a lot of trouble if I did, and I would actually have a salt/pepper shaker to show off to my friends and adoring relatives.
    Parting definitely makes me nervous, although I do it with an appearance of professionalism and insouciance. When I part things with my Benjamin's Best parting tool, it cuts nicely through the piece, but usually leaves me with a nub that I have to trim off. Is this normal?
    OH, BTW, my sharpening must be OK, because I am definitely getting shavings from my tools, and not dust.
    Cheers,
    Roger
    30,008
    ...and it fell, appropriately, into my firewood box...
    Sorry to laugh at the pain of others, but that's funny stuff right there.
    As for cutting a round piece (a cylinder) on a table saw, it can be done, but the workpiece should be held firmly to the miter gauge - clamped preferably. There is a real risk of the piece rotating when it meets the blade, and if that happens, things can get dangerous quickly. It's also important to control the off-cut. Since it'll be round, there's a risk of it rolling into the blade and becoming a missile. Personally, I'd stick with the parting tool.
    Parting has always been tricky for me on a piece that's held between centers on a lathe. When the one piece becomes two, I don't enough hands to catch both pieces and hold the parting tool. For that reason, I don't part anything off with the parting tool unless one end of the workpiece is held in a chuck. If I'm running between centers, I'll use the parting tool down to about the last 1/4 or so, then stop the lathe and use a flexible flush-cut saw to finish the cut. Here's the one I use:
    http://www.amazon.com/Shark-10-2204-...ords=shark+saw
    (And don't forget to loosen the tailstock pressure a bit before starting the saw cut. It helps keep the blade from binding as you cut.)
    Yorktown, Virginia
    5,011
    ....Parting has always been tricky for me on a piece that's held between centers on a lathe. When the one piece becomes two, I don't enough hands to catch both pieces and hold the parting tool. For that reason, I don't part anything off with the parting tool unless one end of the workpiece is held in a chuck. If I'm running between centers, I'll use the parting tool down to about the last 1/4 or so, then stop the lathe and use a flexible flush-cut saw to finish the cut. Here's the one I use:
    Ditto on how Vaughn does it. Also don't forget that pepper mills have that nice hole in the center which you can slide on an appropriately sized mandrel to fix mistakes or finish/sand the top after you part it off. I prefer the band saw for trimming these small pieces, with the caution to feed slowly and hold the piece firmly against the miter gauge so it doesn't spin. Less dangerous than the table saw.
    Jan 2011
    3,798
    All part of the ABC's of turning...
    Section 24, article 13, paragraph 5 of my personal copy of 'Using the Parting tool'...
    A> assume, B> beware, C> caution, D-&-E> DEparting for take-off .........
    Feb 2012
    2,746
    Quote Originally Posted by Ken Cook View Post
    The thing broke off again!
    Cheers,
    Roger
    Mar 2014
    Humid Gulf Coast
    542
    Slip a peice of white PVC sewer pipe over it to use as a catchers mit maybe??
    It's kind of fun to do the impossible
    30,008
    Quote Originally Posted by Scott R Smith View Post
    So now instead of having two loose pieces when the cut goes through, he'll have three.
    As I mentioned earlier, the easy solution is to use a chuck (and a tailstock) instead of turning between centers. That way you only have to catch one piece, and it's possible to have a free hand available to do it.
    Mar 2014
    Humid Gulf Coast
    542
    Yep, agreed...
    Aug 2008
    Reno, Nv
    3,632
    It can be. Pic's would be appropriate...and stuff like speed, angle, diameter...unless you were looking for something else???
    Tellico Plains, Tennessee
    4,351
    I didn't get that he was turning between centers, but like Vaughn, when I turn peppermills, I'll turn the blanks round between centers, but always add a small tenon for a chuck... I usually mark the lengths of the mill and will use the parting tool to divide the blank into the two pieces, then I use a chuck to drill the blank.... after I've drilled the mill, I switch the body to a couple of jam chucks that I made specifically for pepper mills... the top piece gets put back on a spigot chuck to turn the ball I use on the top of my mills.
    Chuck
    Tellico Plains, TN
  1. Made some parting tools
    By Terry Quiram in forum New Tools
    Last Post: 09-14-2015, 02:16 AM
  2. How Sweet it is !
    Last Post: 10-22-2013, 05:48 PM
  3. Parting Tool_Which do you prefer
    By Jim C Bradley in forum Turning Tool Questions and Show & Tell
    Last Post: 12-22-2011, 05:20 AM
  4. Home made parting tool
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 04-19-2008, 10:35 PM
  5. Parting out an Delta LD shaper
    By Jeff Horton in forum Old Ads
    Last Post: 04-24-2007, 05:08 PM
