Results 1 to 9 of 9
Thread: Vee-blocks for drill press for round stock
    I need to drill some 1" or 1.5" OD pipe. To clamp it in place, I'm going to make some Vee-blocks out of wood using my table saw.
    Couple questions
    1) I assume I should cut the Vees perpendicular to the grain to resist splitting. Is that correct?
    2) Should I make both an upper and lower Vee block? Ie, make a sandwich out of the pipe: table->Vee-block->Pipe->Vee-block all clamped together? Or is it enough to clamp the pipe directly? I think we'll be using schedule 80 pvc pipe, so it's pretty tough, but it's not black iron pipe.
    Thanks!
    Dec 2008
    Portland, Oregon
    1,898
    I got this one at Harbor Freight. $9.99 (The 12 on the ruler is cm not inches, it's 5 inches long)
    See it here at: http://www.harborfreight.com/self-ce...jig-92046.html
    Jesus was a Woodworker
    Jun 2007
    4,944
    For this task I cut a v-block as you describe and glue 150 grit sandpaper to the inner "V". This seems adequate to hold the round stock still for drilling if a divot has been established with an awl to keep the bit from wandering.
    VOTING MEMBER
    5,321
    Just rip a 2X4 in half at 45, then reverse the halves and glue them to a plywood base.. Drop the pipe into the 'valley' and drill away.
    Southeast Pa
    2,019
    thats the way
    Thanks for the feedback, guys. Sandpaper is a great idea too, especially because these pipes are going to get really beat-up anyway. A little surface marring in the name of safe drilling is no problem at all!
    May 2010
    Orland Park, Illinois, USA
    278
    Just another thought. Rip the 2x4 as Jim stated. Drill two holes in one, mount to a slotted base for T-bolt and nut. Now adjustable if needed for larger diameters. And of course, add the sandpaper. Click image for larger version.
Name:	v-block jig-page-001.jpg
    Southeast Pa
    2,019
    Quote Originally Posted by Robert Horky View Post
    Well I don't think with a 1 1/2 inch 2x4 this will be an issue....
    5,321
    Quote Originally Posted by Garry Foster View Post
    Right...The (non-adjustable) 2 X 4 "V" should handle most pipe.
    The "V" will be about 3" wide at its top, and that'll handle pipes/dowels 6" or more in diameter.
    Widening the gap between the halves will allow the pipe/dowel to touch the base before the "V", and that'll defeat its purpose.
  1. Center Finder for Round Stock
    By Darren Wright in forum New Tools
    Last Post: 02-27-2016, 12:54 PM
  2. Supporting LARGE stock at the Drill press...
    By Art Mulder in forum Jigs and Fixtures
    Last Post: 01-16-2011, 11:29 AM
  3. Tapering round stock
    By Peter Rideout in forum General Woodworking Q&A
    Last Post: 11-25-2008, 02:26 PM
  4. I need a drill press
    Last Post: 11-03-2008, 04:39 PM
  5. New Drill Press
    By Vaughn McMillan in forum New Tools
    Last Post: 01-21-2008, 04:38 AM
