Results 1 to 10 of 25
Thread: Damaged arbor thread - Pic attached
    5,175
    Finally got down to the innards of the saw and discovered the threads on the arbor where the blade would sit are totally mashed. This old saw wasn't in production long enough to have a chance of finding new parts. So what can be done? I can try to get a picture but things are kind of tight in there until I get enough things apart. Its soaking in Blaster now.
Name:	Damaged arbor.jpg
    Independence, Kentucky
    1,355
    Got a thread file?
Name:	Screen Shot 2014-08-04 at 4.03.02 PM.jpg
    Dec 2008
    Portland, Oregon
    1,898
    I've got thread chasers from 4-40 up to 3/4" if they can be cleaned up.
    Jesus was a Woodworker
    5,323
    Are (were?) they Acme threads? If so, there's little recourse. I'm guessing a loose retaining nut, and a slipping/spinning blade has worn the metal away?
    5,175
    I agree with Jim as to the cause. This is not Acme thread. This is the usual 5/8" table saw arbor, maybe fine thread? Haven't gotten that far yet. I have taps and dies. I'll try to get a picture.
    12,264
    Wow and i thought i like a challenge. My first thought was use a die to try clean up threads and see if it helps. But i would think the arbor has also been hardened so dunno. Just for info if you dont have the die a die that size on its own will set you back quite a bit, i recently priced a tap of 14mm and here it was $40 before tax. So i changed my plan.
    5,323
    ...This is not Acme thread. This is the usual 5/8" table saw arbor, maybe fine thread?...
    If it's 'fine thread' then it's not the usual TS arbor. Delta, Powermatic, Jet, Grizzly, Shop Fox, and who knows how many others, all use an Acme thread in their contractors saws and cabinet saws. Been a long time since I've owned a Craftsman saw, but as I recall, they used Acme threads, too.
    Feb 2012
    2,749
    When you take it apart, can you take it to a machine shop and have a new arbor made? Then you could have Acme threads, too.
    Cheers,
    Roger
    4,701
    Hmm, well I'd take it apart and measure everything to see if there was another arbor that I could make work. Might require replacing the bearings and pulleys as well to make it all go back together but if you can find the right parts it may not be all that bad price wise (less than $100 I think.. if you're lucky anyway).
    Failing that, you're basically stuck building up the arbor. The redneck way would be to use devcon (or jb weld) and carefully file to diameter - I wouldn't expect that to last a really long time. Better would be if there was a machine shop that could lay a few beads around it and then mill it back to the correct diameter. That will probably cost more than the saw is worth.
    Or find another saw with a dead motor and a good arbor and .. well.. the rest is obvious (and then you'll have another saw body to .. make a drum sander? a router table? an I dunno what..).
    Apr 2008
    Independence MO
    561
    Uhm, check your dead saw pile? You've been collecting iron for a reason.
    After using them, I prefer rethreaders/thread chasers and thread files to a die. (may cut more metal off and have issues) I have also done the buy multiple nut trick and use a couple nuts to bring the threads in line, then use a brand new nut when done. (arbor nuts used to be sold at several hardware stores, along with tool brushes) Ace hardware was the one I had better luck seeing that stuff in.
    Check CL, for another dead parts saw.
  1. New Cab Attached to BS Cab
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 03-27-2013, 01:55 PM
  2. TS Arbor Nut
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 04-12-2011, 11:52 PM
  3. beetle damaged ash, burn or continue?
    Last Post: 09-10-2010, 09:51 PM
  4. Rustic Arbor
    By john looser in forum Flatwork Project Showcase
    Last Post: 08-06-2008, 12:26 PM
  5. Barn Razing -tearing down a snow damaged pole barn
    Last Post: 04-23-2007, 10:47 PM
