Results 1 to 3 of 3
Thread: Cover for toaster oven
    Feb 2012
    2,749
    My family has a habit of putting things down on any flat surface, including the toaster oven, which is bad news if the thing is plastic, or wrapped in plastic. At Memsahib's request, I made this little cover to fit neatly over the top of the oven. It is birch panel, finished with a mix of black cherry and chocolate (Yeah, yeah! I applied it with my tongue. ) and four coats of shellac. Didn't put shellac on the bottom, in case it could melt and stick to the toaster oven, which would kinda defeat the purpose.
ID:	84375Click image for larger version.
    Cheers,
    Roger
    Sep 2007
    Plainwell, Michigan
    4,857
    Great idea Roger, we do the same with ours and, of course, plastic melts and did on ours I am going to use your idea iffin you don't mind
    17,477
    the heat doesnt affect the oven or the wooden shelf?
  1. Nephew's first cover
    By Stephen Bellinger in forum Off Topic Discussion
    Last Post: 10-09-2013, 09:32 PM
  2. cover your ears :-)
    Last Post: 06-18-2012, 12:46 PM
  3. Beam cover
    Last Post: 01-04-2008, 06:18 PM
  4. Tempering Oven Build -WIP
    By Stuart Ablett in forum Handtool Project Showcase
    Last Post: 08-03-2007, 10:08 AM
  5. Cover me!
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 02-12-2007, 01:37 PM
