Results 1 to 10 of 15
Thread: How do you choose a bearing
    12,251
    So i looked up a specific bearing that is common for many of our machines when you get down to the basic part number....in this case 6203.
    So this site is recommended all over the web on woodworking searches and it looks like they have a significant variety and this is just the issue that i have come across before.
    Take a look at this search
    http://www.vxb.com/mm5/merchant.mvc?...set=0&Offset=0
    Hope it comes out way i saw it. Anyway all i did was type in 6203 in the search box and got this 2 page list of options.
    Looking at the variations in price one can go from $2.37 all the way in steps thru to $371.77 dont forget the .77
    Now i know the basics like the dimensions matching and sealed versus unsealed and different types of seals but let be real at the hobby end of the scale how do you choose
    Can anyone offer some insight (obviously the sizes have to match what you after) i read up on a couple of bearing manufacturers sites in the FAQ but they only seem to confuse one even more especially when you get into clearance specs like the C3 versus others and the terms like fit versus clearance.
    I can see in some applications for our machines where we would be long gone before the bearing wore out if we purchased specs of no applicability just to be on the safe side.
    If i recall correctly this is the same bearing that was on my Delta band saw and i can tell you that was supposed to be "American made" ( yeah right American assembled) with a 5 year warranty being the "X" rated machines and yet with relatively very little use i found that the bearings were shot and upon changing them i could not believe the difference in the noise never any other gain.
    I am contemplating changing the bearing on my Busy Bee lathe spindle for similar reasons but at the moment its better the devil i know than what i don't.
    In most of our cases these bearings are being placed under overhang weight type loads even if they have a dual bearing configuration on the shaft/arbor. This would add to run out in any rotating shaft being used for turning a cutting tool.
    BTW i did find it very easy to change the bearings on my band saw and the installed ones were not even properly sealed from Romania go figure.
    30,010
    No real help from me on bearing selection, but I'm curious why you want to change out the spindle bearings on your lathe. Are you hearing a specific noise or seeing other symptoms (like bearing slop)?
    Not really sure what you are asking exactly Rob...
    Basically I only buy Japanese made bearings the best in the world IMHO, some of the Euro bearings are good too, but for my money, its NTN, Naichi or NSK.
    Otherwise it really depends on what the application is, the speed and the environment of the bearing. I would imagine for your bandsaw regular steel shielded ZZ bearings would be fine.
    Mar 2014
    Humid Gulf Coast
    542
    Made in China, I'd probably pass.
    Made in Germany, Japan, the USA, Canada, or Northern Europe, I'd pick a lower price point and see how long it lasts.
    If it burns out, pick a couple of price points higher.
    It's kind of fun to do the impossible
    12,251
    Thanks for the input guys. Vaughn since changing out bearings on my bandsaw and experiencing the difference, I have just had it in mind to give my lathe a go and see the difference. My bandsaw experience really conveyed the point that not all bearings are created equal even if they look the same.
    Stu my thoughts were exactly what you said...Stick to Japanese.
    But check out the range of price for the same bearing.
    My question is say one purchased a Japanese unut for i dunno lets just say $10 then $40 and say $150 or even $300. What would the practical difference be.
    Would you ever put a ceramic roller bearing into a woodworking machine?
    Take a table saw, i bet the bearings on say a sawstop saw arbor versus a table saw of equivalent power at our local Busy Bee tai chi import special are not the same quality if the were the same size and format.
    So we have people examining arbor run out etc and perhaps simply upgrading the bearings would make a significant difference is what i am thinking. At the end of the day its a vital part of rotating machines.
    5,171
    Back in the day when I was teaching, I had a bearing house rep come into class and explain the differences in bearings. Something he said then has stuck with me all these years later. He said bearings were manufactured in few places in the world. The intention to manufacture a bearings to best military spec did not always play out, but the bearings that failed, passed lessor tests, and that there was a market for nearly every bearing manufactured. The cost escalated downward of course. So maybe quality we are unable to either measure or even appreciate plays a big role. Since those days, a much greater manufacturing presence in the Far East may have spawned bearing manufacturers with lesser aspirations of quality. The numbers on a bearing have lots of information built in. Some of it is the level of quality. Beyond that I cannot explain, except for this: The bearings used in that 10 year comet chasing space craft probably ought to be of greater quality than even the Sawstop! Just sayin....
    The shielded bearings from VXB have served me well at a good price. I used them to replace the stock bearings on my larger bandsaw. I bought enough for a few change-outs since the price was right. Its been years and I am still on the first set. Not so sure that worked as I had planned but, I still have plenty of spares .
    Southeast Pa
    2,019
    Rob I really don't make it all that difficult as I determine wh at type of bearing I need and go buy it. You know you don't want an open bearing. You also know you don't need ceramic so basically you need sealed or shielded and then the class determines the tolerances.
    Class info
    www.ntnamericas.com/en/pdf/2200/tolrance.pdf
    East Freeetown, Massachusetts
    3,019
    There are a number of different reasons to look at bearings a bit differently.
    First off let me say that American made bearings are sometimes going to be a high quality product. Last year I was at Timken bearing in Lebanon New Hampshire and I will vouch for that manufacturer being a high quality outfit. Almost needed surgical gowns just to tour the place. Bearing manufacturers are about the only manufacturing places that rival the gage makers in tolerances of manufacturing processes.
    About bearings ---
    We don't always see or think about what bearings are used for, besides our selection.
    There are speed requirements and load requirements and life requirements
    Some applications have stringent runout requirements.
    If I had some REAL need - as I did in designing a hobbing attachment for a Maier Swiss Turning machine - I would call a bearing supplier and have them come in to visit me and discuss the requirements and have them spec out a bearing for me. I would not try to spec it out myself - not in a critical operation.
    When I buy machines (not table saws and stuff like that - I buy machines in the 1/2 million dollar range) - I CERTAINLY, am into bearings - on those machines. Sometimes bearings change size as they warm up and that affects the machine performance. Bearings mean a LOT to me.
    Imagine a Router with bearings that are under rated on speed requirements.
    Some bearings will carry a heavy load.
    Some bearings need thrust characteristics.
    I can easily see the applications for a $300 bearing vs a $10 bearing.
    My estimation for our woodworking is a "decent" low cost "SEALED" bearing, not the chinese ones.
    I would not hesitate to buy the American Made Timken bearings - price being the governing factor.
    Japanese and German bearings are also great choices.
    Except for a router - just about any "decent" - not chinese bearing will serve us well on a hobby woodworking machine.
    A router will need certain "speed" characteristics.
    Most if not all of our bearings will be single row ball bearings. I would add - sealed, and possibly lubricated.
    So, on our woodworking machines - that really boils it down to the major important stuff being -- SIZE.
    30,010
    ...Vaughn since changing out bearings on my bandsaw and experiencing the difference, I have just had it in mind to give my lathe a go and see the difference. My bandsaw experience really conveyed the point that not all bearings are created equal even if they look the same...
    You mentioned that your bandsaw became quieter with new bearings. What part about the bandsaw was quieter? It is the wheels spinning or the roller bearing blade guides? Is your lathe making any appreciable noise? Unless your lathe is whining or squealing, I don't think you'll see a noticeable difference with new bearings, regardless of the price.
    Personally, instead of spending the time researching and replacing bearings, I'd spend the time turning some stuff.
  1. woodworking vice, too many brands to choose from
    Last Post: 07-13-2012, 05:11 PM
  2. Come on folks get out and vote .....all you need do is click to choose..
    Last Post: 04-06-2012, 11:36 AM
  3. Before you choose to use Butler Hinges stop
    Last Post: 07-04-2011, 11:44 PM
  4. Which Chuck to choose?
    By Dimitri Schreiber in forum General Woodturning Q&A
    Last Post: 07-10-2010, 01:36 AM
  5. Help me choose a wood.
    By Brian Corrigan in forum General Woodworking Q&A
    Last Post: 05-06-2010, 09:18 PM
