Results 1 to 10 of 14
Thread: Dad's Workshop
    Southern Louisiana
    947
    Dad's Workshop
    well here are a few pics of what will soon be my temp shop. It is my dad's new shop and I will soon be building one either the same size or slightly bigger.
    It's 30x54 with a 10' eave height. 6" metal stud construction with roof trusses instead of beams. It very easy for a homeowner to assemble. All that is needed is a little help from friends to lift stuff into place. It's all joined by self tapping screws.
    what you're gonna see took me and my dad about 6 hours of prep work getting the base plates drilled and bolted to anchor bolts. Then we built the end walls (these 2 walls do not have trusses) After the prep work was done we called in the troops for an early saturday morning start and by noon we had the building up and stable. There was still alot of work to be done running all the channels around the sides on 3' centers and on the roof as well. The building is much further along now but my dad lost the urge to take pictures as the process went along. No need to worry I will be fully documenting the build of my shop so you can see the full process take place.
    I'll try to get some pics today of where we stand right now. we are basically done with all 4 walls and are ready for roofing.
    The concrete slab was done by others, but when we checked the diagonals for square it was out by 1/8". I'd say thats purty darn close!!
    thanks for looking
    chris
    Attached Thumbnails Attached Thumbnails shed.jpg   shed1.jpg   shed2.jpg   shed3.jpg   shed4.jpg
    Charleston
    917
    Thanks for sharing Chris. I hope the progress your Dad has made will get documented for his own good. It is always good to have pics of various stahes of construction for insurance purposes as well as you can use them as reference.
    Michigan
    2,436
    Looks like it should work out well Chris....and a old boy told me this one once " A 1/8" is probably rough enough" Yeah it is definately close enough. Look forward to the completed pics.
    Woodstock, GA
    178
    Looks good Chris, it's nice when you can learn some of the mistakes on your Dads shop before you build yours. Can you share where you purchased the building kit from?
    Toronto, Ontario, CANADA
    2,332
    Interesting to see this kind of construction. It's not for me (give me wood anytime), but I do like to see how it works.
    What's with all the massive shops that many members here have. or are going to have. My friends think that my shop is big, but it could drown in a lot of the shops of Family Woodworking members.
    Cheers, Frank
    Steve Clardy Guest
    Looks like a great start
    Southern Louisiana
    947
    joe,
    unfortunately he has pics from the slab, the very beginning of the shop and i think maybe up to the first sheeting going on the walls. i guess he really hasn't missed that much. i'll make sure he gets pics from here on out.
    as for using his as reference, this one is the second one i have been involved with building. a friend built one the same style and size but with 14' eave height. Not to mention, he built 3 before his and some one he knows built some before those. So we've kinda got a colaborative effort going. by the time i build mine i'll hopefully have most of the kinks worked out. i already have a bunch of ideas to make it faster and easier.
    steve,
    yes 1/8 is good enough, considering my friends slab for his shop which was the same was almost an inch out in the diagonal. luckily we were able to just lay the shop base plate square and go from there.
    Ken,
    gonna send you a pm
    Frank,
    well in a perfect world where i had the money to build the shop the size i NEED out of wood, you better believe i would be doing that. unfortunately i am not able to accomplish both of those. so my needs for space came first.
    it probably would have cost me 3 to 4 times what it cost to build this one.
    and although this isn't my shop, mine will be this size, actually i'm checking to see how much it will add to the cost to add another 6' to the length. the reason i need such a massive shop is that i plan to be doing woodworking for a living very soon. and i don't wanna have to add on later.
    thanks steve
    thanks for the comments everyone. i'll try to get some more pics with the walls up later.
    thanks
    chris, no matter what sized shop you build in 5-10 yrs it`ll be to small. all of us woodworkers are pretty much the same in that good deals on lumber and tools are hard if not impossible to pass up. that`s not to talk about our 753 unfinished projects that eat up valuable floor space, wall space and on occasion back yard space ....if you don`t mind me askin` what`s the frame running? not counting the skin,roof or slab...thanks, tod
    Southern Louisiana
    947
    tod,
    unfortunately I know you are right. and someday i prolly will add on. but hopefully not for at least 5 years or more.
    and no i don't mind. it will be hard to break it down because i don't know what everything costs separately. my building is 30x54 with 12' eaves, and for everything, including frames for the a roll up door, entry door and 3 windows, mine ran me right at 7800. i believe that the cost of their metal went up right after that so it may be more now. hopefully that gives you a pretty good idea of what it would cost. she is supposed to be calling me back with the price to add 6' to the length, when she does i'll ask what the break down is for you.
    thanks
    chris
    thanks chris! that`s waaay cheaper than a wood structure even buying the wood wholesale. do you know what the wind/snow ratings are for this type of construction? long term my plans are to change locations and i`d like to explore all different construction types and this is one i`m not firmilar with....this is 16ga steel right?thanks, tod
  1. New Yankee Workshop #411
    By Larry Cronkite in forum General Woodworking Q&A
    Last Post: 12-16-2010, 08:54 PM
  2. New Bench For New Workshop
    By Matt Fornes in forum General Woodworking Q&A
    Last Post: 11-17-2010, 06:09 PM
  3. Woodturning Workshop
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 07-01-2010, 06:18 PM
  4. My Workshop
    By Mark Stafford in forum Shop Tours
    Last Post: 05-24-2009, 10:46 PM
  5. My Workshop
    By Rick Doyle in forum Shop Tours
    Last Post: 01-06-2007, 07:05 PM
