Results 1 to 10 of 15
Thread: Stuck spur centre
    Feb 2012
    2,749
    Stuck spur centre
    I went to gently tap the spur centre out of my lathe headstock, and it won't budge. I have tried hitting the rod with a wooden mallet, and twisting with a wrench, and have squirted a little WD-40 on it. I cannot continue my learning process if I can't get that centre out! I may have to give up and do some flatwork until I figure this out.
    Help me, O Family Woodworkers; you're my only hope!
    Cheers,
    Roger
    868
    You need a bigger hammer, Rog! Try a steel one, seriously.
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Aug 2008
    Reno, Nv
    3,632
    You should have a knock-out tool. Run that through the headstock and smack the sucker.
    868
    Quote Originally Posted by Jim Burr View Post
    I assumed he was using a knock-out tool!
    Feb 2012
    2,749
    Thank you! I just needed reassurance that I could whack it really hard. I have a home made knockout tool, as the seller couldn't find the one that came with the lathe. I am also using the safety key from my drill press in it, because they couldn't find that, either.
    I will let you know...
    Cheers,
    Roger
    Feb 2012
    2,749
    Dumb thing is OK now...
    I picked up my son's 6 lb. mallet that was lying around, and gave the knockout bar two whacks. The first whack shattered the nice wooden knob I had made for the knockout bar, the second sent the spur centre and the knockout bar flying the length of the lathe, and now I can get on with my work.
    Thanks again!
    Cheers,
    Roger
    Glad you got it out!
    Use a green scrubby pad to clean the spur center off and the inside of the MT on the headstock, and I bet this won't happen again.
    new york city burbs
    10,188
    this is why I read threads , get all these little helpful hints from experienced woodworkers/turners
    Human Test Dummy
    30,015
    I'll echo this. It's also important to ensure both the center and the inside of the MT on the spindle are good and clean before inserting the spur center into the spindle. The inside of my spindle got chewed up to the point where I had to use a reamer to clean up the galled metal, simply because I didn't make sure things were clean first.
    Also, don't put the spur center in the spindle, then attach the workpiece by whacking it with a mallet into the spur. This forces the spur center in too tightly, and can cause it to get stuck. Instead. drive the spur center into the workpiece off the lathe, then mount the spur and workpiece onto the lathe at the same time. Even if the spur doesn't stay "stuck" to the workpiece as you're mounting it all, the workpiece will have the indentations from the spur, and it'll be easy to match those up with the spur when you bring up the tailstock to hold everything in place.
    868
    http://www.woodturnerscatalog.com/p/122/3651/TaperMate-Morse-Taper-Cleaner
    I don't have one, but wished many times that I did have one!
  1. Steb Centre
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 06-26-2015, 12:02 PM
  2. two spur drive center?
    By Ned Bulken in forum General Woodturning Q&A
    Last Post: 01-02-2013, 07:38 PM
  3. Disappointed Craft Supply Spur
    Last Post: 09-01-2009, 02:57 AM
  4. Time for a new spur drive... What to get?
    By Rich Tota in forum Turning Tool Questions and Show & Tell
    Last Post: 11-04-2008, 11:25 AM
  5. Entertainment Centre
    By Thomas Smith in forum Flatwork Project Showcase
    Last Post: 05-02-2007, 11:43 AM
