Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: 2-in-1 bed for the daughter as the baby is on board
    May 2010
    Orland Park, Illinois, USA
    278
    Started this in advance, anticipating what has now become a reality. Now have a deadline to meet so the pressure is on.
    Starting here:
Name:	3-in-1 bed Jatoba.jpg
    The sides will be detachable and replace with longer pieces to hold a full size mattress when the crib is no longer needed. I am skipping the making of a 'toddler' foot board thus, the 2-in-1, not the 3-in-1 you may have seen in plans, other projects.
    Wood: Jatoba and Walnut ... it will be HEAVY. Please note, the pics below are in the right group but not necessarily in the right order/sequence of build as they seem to take on their own order when multiple ones are selected at a time.
    Have planed, ripped, crosscut, mortised (158 and counting) and slotted all the Walnut pieces. Some shots along the way:
ID:	84785Click image for larger version.
ID:	84786Click image for larger version.
ID:	84787Click image for larger version.
    pulled together the bent wood lamination:
ID:	84792Click image for larger version.
ID:	84791Click image for larger version.
ID:	84790Click image for larger version.
ID:	84789Click image for larger version.
    more to come ...
    17,472
    what glue did you use for the lamination? looks like a great start there
    May 2010
    278
    Legs are complete except for the centers. I will plane down some 2x4's and fill in the centers.
    Since that locking miter takes such a large cut and Jatoba is hard as a rock, I used a shim technique on the fence to ease into the final depth. I set up the bit height/depth with scrap soft wood then used these shims on the fence:
    Then the headboard/footboard top/bottom rails:
ID:	84796 Click image for larger version.
    then the mortising/slotting of the same:
ID:	84798 Click image for larger version.
ID:	84799 Click image for larger version.
ID:	84800 Click image for larger version.
    and some dry fitting is starting
ID:	84802 Click image for larger version.
    more to come, thanks for looking.
    May 2010
    278
    Larry,
    I used DAP Weldwood Plastic Resin Glue. I have used in the past on pub table chair legs. Good open time, easy to apply, solid as a rock when cured. I can tell you when I removed the clamps from the jig, there was NO spring back. See for your self:
    You can see it did not budge from the form on the right side as the left side was removed.
    30,017
    Looking great so far, Robert. And I'll second your motion for the Weldwood Plastic Resin glue on bent laminations. I've had great results from it myself on the few bent pieces I've made. I've also used it on higher-end cutting boards where I didn't want any glue creep afterward.
    17,472
    thanks, robert i thought so from what i saw behind your picture.. but figured i would ask for sure.. as for filling those legs i dont think i would bother with that the legs once glued will be very strong as they are and if you need wood for mortises then just plug the top and bottom where needed..but a shorter tenon would be ok to.
    12,256
    Very nice design and work Robert thanks for posting. Love the top of that headboard and the shape you got in it. Have you thought of adding a bead with router bit or scratch stock to that top edge, it would help emphasize the outline shape a bit and make it stand out a bit more. Given the steps are nice and shallow and gentle.
    I was wondering about the filling of them legs but Larry answered my question.
    Jan 2011
    3,798
    May 2010
    278
    Made some additional progress. Filled the legs
    Did the mortises for the headboard/foot board rails:
ID:	85296 Click image for larger version.
ID:	85297 Click image for larger version.
ID:	85298 Click image for larger version.
ID:	85300 Click image for larger version.
ID:	85299 Click image for larger version.
    more to come ...
    5,321
    Just curious...why did you fill the legs?
    As a side note - since the filling is a different wood (pine or poplar?) the different expansion rates might pop the mitered joints in the outer legs.
  1. Box for my daughter
    By Bob Gibson in forum Flatwork Project Showcase
    Last Post: 05-06-2014, 01:23 PM
  2. Baby Doll Craddle for my Grand Daughter
    By Jim Krager in forum Flatwork Project Showcase
    Last Post: 07-19-2013, 05:25 PM
  3. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  4. Oh Baby! Grizzly H8145 Baby Table Saw
    By Frank Townend in forum New Tools
    Last Post: 04-18-2009, 05:47 PM
  5. My daughter's first pen.
    By Joe Mioux in forum Turning Tool Questions and Show & Tell
    Last Post: 02-17-2009, 06:45 PM
Tags for this Thread
