Results 1 to 8 of 8
Thread: Pen Drillling Vice....
    15,811
    I looked at the self centering vices for drilling pen blanks, but the problem I foresaw was that a lot of my pen blanks are cut green and then dry, so they are seldom straight, and or square......
    I've seen various drilling vices on the net, and this is what I came up with.
    The vice is just two pieces of 21mm thick MDF for the jaws, and one piece on the bottom that makes a base. There is a hinge on the right side, as I squeeze the vice closed with my left hand. I use one vicegrip c-clamp to hold the pen vice to the DP table, doing so gives me one pivot point, front to back, if you will, then the DP table is not locked to the DP column, so the table itself provides the left to right adjustment. I found it to work VERY well, I could line up the center of the blank for drilling quickly and easily.
    In this pic, with the vicegrip removed, and the pen vice open, you can see the hinge, on the right, and the two clean out holes I made.
    Here I'm drilling a blank, I'm just holding the vice closed with hand pressure.
    Here you can see the bit of dust that has fallen into the vice, but because of the clean out holes, it is not in the way............
    ...............and after 20 or so blanks, all I had to do was give it a blast of compressed air and it was clean again.
    Here is a blank that was not square at all, but the pen vice still worked fine!
    I use the same pen vice when I mill the ends of the blanks after inserting the brass tubes, it works really well for that too.
    Between the DIY pen press and this pen vice, my productivity has gone way up!
    11,899
    Very clever. I use a cross-slide vice from Grizzly. Yours is not unlike some commercial types. BTW, the very first picture would not open for me.
    15,811
    Well, I got my ideas from various places.....
    The first pic opened fine for me....
    The Woodlands, Texas
    83
    You Rock Stu!
    Hello Stu,
    You Da Man! I wish I was as clever as some of you chaps that build your own jigs! Good luck and best wishes to you and yours!
    Better Woodturning and Finishing Through Chemistry...
    Steve Russell
    Eurowood Werks Studio
    Professional Studio Woodturner
    Honolulu, Hawaii
    1,103
    Yeah Stu,
    That's it exactly. Bernie's is a little smaller than yours but same idea. I'll be making one soon now. Thank you for the link too. (Made it a lot easier that way )
    Looking at the column on your drill press makes me ashamed of the way mine looks. (Now I have to take it apart again and polish it, and the tables too. ) I only blasted it to get the rust off. The major parts of the press got painted Black. (This was before my joining the OWWM restorers ranks. Function ruled. )
    Pictures later.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Westphalia, Michigan
    955
    Mine is similar to Stu's. I just used 2 pieces of scrap oak and cut 2 different size 45's in the face to accomodate 5/8 and 3/4 blanks. I then clamp it in a machinest's vice. I always put a scrap piece of MDF underneath to prevent blow-outs. The height of the pen clamp is 2-1/2" high. (maybe 3") I can't remember. I am looking into a production oriented set-up with a Destaco clamp that pushes into a corner. I just have to make a nylon piece with a 45 in it so that the blank is fully supported. Maybe I'll post a picture when it's done.
    Goodland, Kansas
    4,834
    Good looking tool Stu. Looks like it works pretty good.
    Bernie W.
    11,899
    Opened today. Just musta taken ten days to git across the ocean.
  1. In Praise of the Simple Leg Vice
    By Stuart Ablett in forum Neander Woodworking Q&A
    Last Post: 02-29-2016, 05:12 AM
  2. Great Leg Vice
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 03-29-2014, 01:13 PM
  3. New vice from LeeValley
    By Toni Ciuraneta in forum New Tools
    Last Post: 11-24-2010, 08:24 PM
  4. Is this Wood Vice O.K. ?
    By Ron Potter in forum General Woodworking Q&A
    Last Post: 09-12-2010, 01:12 PM
  5. Vice...
    Last Post: 07-26-2008, 04:42 AM
