Results 1 to 10 of 12
Thread: Quick Build Thread of an Inlay
    Aug 2014
    St. Mary's, Georgia
    398
    Here is a Wood In Wood Inlay in a Island Top I made from Mackore an Sycamore. The client wanted a Inlay of one of my Eagles, an I was just making one for another project.
    Good client so moved it to the Island Top
    First made sure top is nice an flat an mark out the area for the inlay I used a pencil an exco blade to do the outline
    Next I set the depth an started removing a lot of the material with a router an down spiral bit 1/4 inch so little chip out
    it took 2 days of removing material an using chisels to for the sharp edges
    Keep your area clean an getting ready to fit up most of the inlay
    Here is the first fit-up
    As you can see there is no eyes an face of fish but its coming
    Next sand down to level an started the face of the fish an did the eyes also Used Mother of Pearl for all eyes
    I put one coat of poly on to pop the grain
    All done ready to go to clients home to be mounted on cabinets, took 6 coats of poly to get this right an had to hand buff it with wax
Name:	2012-01-05 14.51.28.jpg
    Each way you see this an taking pictures it changes as if it wants out
    https://www.facebook.com/BgCouger
    If you are going to make something nice, make it with a statement, use quality an do it right the first time
    Independence, Kentucky
    1,354
    Beautiful Roy, your work amazes me
    S E Washington State
    3,777
    VERY BEAUTIFUL!!
    "We the People ......"
    Southeast Pa
    2,019
    I overuse the word but Awesome is the best word I have..
    Jan 2014
    Providence Forge, VA
    51
    As I said before, Roy, you are an artist!!
    Earl
    Oct 2009
    Near Gassaway,West Virginia
    105
    Roy that is very impressive work. Would be nice to be in your shop and watch how you do what you do. Appreciate you taking the trouble to document your work for us.
    Fred
    steercreekwood.com
    Austin, Texas
    1,448
    Looks great, Roy. But I bet the amount of work that went into creating the inlay was far more than the effort to inlay it.
    Charlie Plesums, Austin Texas
    Yorktown, Virginia
    5,009
    Truly beautiful!
    Mar 2014
    Humid Gulf Coast
    542
    I noticed at first you leave the bird above the tabletop, then sand him down level.
    Would you do the same sand down if the table had a veneer top, or would you keep removing substrate with the router until the the two were level?
    Also, what is a good thickness to work with when making the individual bird peices?
    It's kind of fun to do the impossible
    Aug 2014
    St. Mary's, Georgia
    398
    Most of my Inlays depend on what there going into, if it is a hard wood Like the Makore I like 1/2 or thicker if I'm going into a softwood like Cedar I do my inlays 3/16 to 3/8 now going into a veneer I like to go between 1/8 to 1/4. When Inlaying on Veneer I like to be just a little bit proud where I only need 320 grit to bring it level by hand. As you can see I like using MOP also specially for eyes or other parts , most of my MOP is 60 thousands thick. The biggest thing also you need to look at is what glues you are using I like CA so I can stabilize the wood also. now in this thread I am building now is an Inlay but using the cube effect an trying to make a flower, the material is 3/16 " its going into Cedar, but its only one of the twist to that build, yes I'm working at least 2 days ahead of the posting. What you don't see is there is a second one getting worked on also its the prototype in which will be auctioned off for the Shiners Hospital if its good enough, if its not it get burned. Most of my projects I work on there is a prototype somewhere or it ashes, due I'm still learning also.
    Here is the thread of the Blanket Chest
    http://familywoodworking.org/forums/...e-twists-to-it
  1. Build thread: 28 ft. gaff rigged sloop
    By Roger Tulk in forum Flatwork Project Showcase
    Last Post: 02-20-2015, 04:30 PM
  2. Build Thread for Hope Chest
    By Roy Millsaps in forum Off Topic Discussion
    Last Post: 08-13-2014, 09:15 PM
  3. Kitchen Hutch - Build Thread - Done
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 08-26-2013, 07:05 AM
  4. G&G Inspired Chest of Drawers - Build Thread
    Last Post: 01-14-2013, 04:14 PM
  5. Aquarium Stand .. build thread
    By Robert Horky in forum Flatwork Project Showcase
    Last Post: 12-14-2011, 11:10 AM
