Results 1 to 10 of 27
Thread: Rubbing out a lacquer finish methods
    17,472
    what are your preferred methods for rubbing out lacquer finishes and how long after its sprayed?
    Thomasville, GA
    5,995
    When I've done a rubbed out finish, I usually start with fine pumice, soapy water to spritz it and a soft cloth like t-shirt material. I wait a week or so to begin the process. After getting it the way I want it in that step, I switch to rottenstone and repeat the rubbing with soapy water and a cloth. Now, I have also done the rottenstone step using a 6" buffer like you use for car polish. After I'm satisfied with the rubout, I use the buffer to apply and buff out a polish.
    Bill Arnold
    5,172
    For your reading pleasure, Jeff comes through.
    http://homesteadfinishingproducts.co...-out-finishes/
    Apr 2009
    Outside the beltway
    5,255
    Larry depends on the size of the piece. Sometimes I'll do a similar rub as french polish only with lacquer thinner and briskly rub it out while its still curing.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    17,472
    i have some drawer frnts and the tops that i am looking to do..dave.. the drawer frnts need it the worse..
    Apr 2009
    Outside the beltway
    5,255
    2000 wet sand and wax is the quickest, or lay another coat on heavy.
    17,472
    the ones i have trouble with are the one that i toned to match the others and used a different gun, so got worse pattern and need to make them right. i took and used some 400 abranet anf then some 1000 mirlorn and think that will fix them.. what is this mirlon lube will something else work? mineral spirits?
    Apr 2009
    Outside the beltway
    5,255
    Rubbing compound.
    17,472
    this mirlon lube is for the synthetic steel wools ,, to aid in lubrication of the abrasive.. but i dont have any,, used soapy water thus far
    5,172
    to add to the fire.
    A friend uses Howard's Feed N Wax with gray pads. Smells really good, too. Used to be a product called WoolWax. No longer available. I used to give a bottle of Howard's when I delivered a piece and a short instruction sheet on how to care for their new furniture. Howard's is available at HD, etc.
  1. home brew lacquer finish, good, bad, or ugly?
    By hu lowery in forum Finishing School
    Last Post: 06-23-2013, 04:13 PM
  2. Calling all lacquer sniffers! (finish question)
    By scott spencer in forum Finishing School
    Last Post: 08-27-2010, 06:07 PM
  3. Calling all lacquer sniffers! (finish question)
    By scott spencer in forum General Woodworking Q&A
    Last Post: 08-26-2010, 06:08 PM
  4. rubbing oil
    By Frank Fusco in forum Finishing School
    Last Post: 10-07-2009, 03:59 AM
  5. what sealer/lacquer for BLO bowl finish
    By Nathan Hawkes in forum General Woodturning Q&A
    Last Post: 01-19-2008, 03:23 PM
