Results 1 to 10 of 13
Thread: Silicone bottle stoppers
    Honolulu, Hawaii
    1,103
    Hi gang,
    Some time ago I purchased some silicone bottle stoppers from Woodcraft so I could turn some stoppers for friends. Well, time went on and life got in the way and those never got made. Now, I am looking to find out how you people fasten the silicone to the turned part (assuming it would be a dowel or a spigot turned from the original wood). Thinking glue? silicone sealer? or??? what do you use?
    Thanks in advance for any info.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Thomasville, GA
    6,000
    I haven't actually done what you describe, but I've read about a couple of options as I studied bottle stoppers in general. One method is to turn a 5/16" to 3/8" tenon on one end of your blank, then turn it around to finish turning. Drill a hole in the cork and use either epoxy or CA to attach. You could also drill both the cork and turned handle and use a dowel to join them.
    Bill Arnold
    Bill, Tony is talking about the silicone stoppers, not the cork ones.
    http://www.woodturnerscatalog.com/p/...e-Dowel-5-Pack
    Tony, I've got some of these stoppers, but haven't actually used them. Although the ones I got came with the pre-sized dowels, it seems it'd be pretty easy to make your own. I think I'd go with silicone seal/adhezive to attach the stopper to the dowel.
    Tellico Plains, Tennessee
    4,353
    Tony,
    When you ordered the silicone sleeves you should have also ordered the little dowels... I make these all the time and usually order from Packardwoods and the dowels come as part of the stopper.... you don't want to glue the sleeves to the dowels... the beauty of these little silicone stoppers is that you can slip the sleeve off the dowel for washing and cleaning without having to get your wood turning wet.
    I usually drill a 3/8" (I think) in the turning for the dowel to fit in, glue the dowel into the turning and then slip the sleeve over it.... here are a couple I've done... I do two styles... one has the silicone stopper at the bottom of the turning and the other style I do has a recess drilled into the turning and the stopper is "hidden" and the turning fits down over the bottle top.
ID:	85020Click image for larger version.
    Chuck
    Tellico Plains, TN
    Thomasville, GA
    6,000
    Bill, Tony is talking about the silicone stoppers, not the cork ones. ...
    Yeah, OK. I was thinking about the synthetic (silicone, I think) "corks" used by a lot of wineries now.
    Bill Arnold
    ...you don't want to glue the sleeves to the dowels... the beauty of these little silicone stoppers is that you can slip the sleeve off the dowel for washing and cleaning without having to get your wood turning wet...
    Thanks for the info, Chuck. That makes sense.
    Honolulu, Hawaii
    1,103
    So, actually, all I would need is to make the tenon/dowel so it fits snugly into the silicone but still can be removed for washing. Snug enough so the silicone insert would not slip off the tenon when pulling it out of the bottle.
    Oh, and I bought these stoppers from my local Woodcraft store. I don't recall seeing the dowels with or near them. I didn't know then, now I do.
    I will give this a try. Thanks everyone for your help. Aloha.
    Honolulu, Hawaii
    1,103
    Silicone-bottle-stoppers
    Chuck, I also like your "Hidden" design.
    Phoenix, AZ
    112
    I've never done one of these so this is second hand info, but, I saw a demo yesterday and the demonstrator said the wood dowels slip out of the silicon when you put your "chardonnay in the fridge." Temp changes and the glass, wood and silicon all expand and contract at different rates. He uses a wooden pin glued in from the bottom up into the dowel. As I said, no personal experience, but he has had customers complain about trying to get the silicon out of the bottle when it separates from the rest of the stopper. I think some testing is in order. Send me several bottles of wine and some stoppers and I'll volunteer.
    Quote Originally Posted by Ken Easley View Post
    ... I think some testing is in order. Send me several bottles of wine and some stoppers and I'll volunteer.
    Always great to see one forum member willing to help out another. Such a selfless gesture!
  1. Bottle Stoppers
    By Diana Kell in forum General Woodturning Q&A
    Last Post: 12-18-2013, 07:25 PM
  2. new bottle stoppers
    By Dan Noren in forum Lathe Project Showcase
    Last Post: 01-27-2010, 01:39 PM
  3. Bottle Stoppers
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 10-23-2009, 01:39 PM
  4. Some Bottle Stoppers
    Last Post: 10-01-2009, 03:07 PM
  5. Some bottle stoppers
    By Don Baer in forum General Woodturning Q&A
    Last Post: 11-01-2006, 02:29 AM
