Results 1 to 7 of 7
Thread: wiring in a new switch
    5,533
    OK guys... help me puzzle out this
    diagram... I'm wiring up a replacement paddle switch from Grizzly. I get that pins 14 and 24 go to the machine side and 13 and 23 go to the source... My question is the ground l, does that go through pin 13, or does it bypass and go directly to a lug on the machine? I'm putting a switch on my jointer; it doesn't have a switch, so simply mimicking the existing set up won't work.
    -Ned
    30,008
    The ground bypasses the switch. Ground should always be continuous, not switched*.
    *There are exceptions on audio circuits, but unless you're plugging an electric guitar into the machine, you won't be needing to switch the ground.
    4,698
    Pin 13 is the hot, you definitely do NOT want to wire the ground to pin 13 or the excitment will short lived and sparktacular.
    Wire the ground directly to the lug on the machine.
    5,533
    thanks guys, It's been awhile since I read a diagram like that.
    -Ned
    Independence, Kentucky
    1,354
    That's not a good wiring diagram for someone that isn't too familiar with wiring, appears to be form overseas perhaps??
    They should use the universal grounding symbol I think. Of course what do I know?
    Apr 2008
    Independence MO
    557
    Quote Originally Posted by Charles Hans View Post
    I thought it looks like they did, use the symbol for earth ground?
    Power source is the plug, although machine might have been more clear with the term motor, instead of machine. (machine, motor and load could all be used there, though)
    Honolulu, Hawaii
    1,103
    Ned, "power source" appears to be a cord, with 3 wires, black,(hot), white(neutral) and ground. The ground does go to a lug (screw or bolt) on the machine. Does look fairly simple.
    Ah,,,to live in Paradise!
    Registered voting member
  1. 220 V wiring question
    By Allen Bryant in forum Carpentry and Construction
    Last Post: 09-24-2014, 06:41 PM
  2. Wiring for my new DC.
    By John Pollman in forum Off Topic Discussion
    Last Post: 04-24-2013, 01:58 AM
  3. Switch Wiring
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 05-10-2012, 04:51 AM
  4. Switch Hitter vs Switch Pitcher
    Last Post: 06-17-2011, 12:53 PM
  5. wiring a reversing switch
    By Paul Hubbman in forum Old Iron
    Last Post: 07-21-2008, 02:58 PM
