Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Here's your sign!
    Constantine, MI
    7,887
    Here's your sign!
    This is my next project, and it's a paying one! This is a lawn sign for a local financial advisor. He has secured the actual signs, painted metal, sign permits and dig line mark outs. I'll supply the construction and installation.
    The post is a full 6x6 cedar timber and the arms are nominal 4x4 cedar. I'm thinking about white oak for the sign frames. The arms will mortise into the post with 2 1/2" square tenons that are 1 3/4" deep. The chain is a substantial link and I'll use an angled hole at the end of the arm with a counter set nut to pull the slack out. If that's not clear sorry. The pictures will make it cleared than I can with words.
    www.wrworkshop.com
    13,431
    Congrats on the gig Rennie. Looks to be a fun project.
    Jan 2011
    3,798
    Yep >
    Thomasville, GA
    5,990
    What they said!
    Bill Arnold
    30,002
    This will be fun to follow.
    Austin, Texas
    1,448
    One suggestion is that you NOT use concrete at the foot of the hole. The concrete is hard on the wood. If there is any wobble, the block of concrete will just make space around the block, which is then almost impossible to fix. Have you ever seen a telephone pole set in concrete?
    The best way to set a post (or a telephone pole) is by packing sand and gravel tightly around the pole, pounding it down every couple inches of fill. I recommend sand or gravel so that it doesn't shrink when it dries out. If you use rocks, avoid "river rock" - highly rounded - use the sharp edge rocks like used as ballast on railroad tracks (I worked on a track gang in my youth).
    I know lots of residential fence posts are set in concrete, since it is fast and easy, but I have also replaced too many fence posts that were "loose" in the ground, or that had rotted with the caustic cement.
    Charlie Plesums, Austin Texas
    Constantine, MI
    7,887
    Here's your sign!
    Hi Charlie,
    Actually I had made two drawings for the city one with the concrete footing and one in gravel and Packed earth. Just in case the city required concrete. Turns out, they do not.
    So, no worries, I will be putting it in packed earth not concrete. I agree with you that concrete is not the best way to go for a wood post.
    www.wrworkshop.com
    Constantine, MI
    7,887
    Here's your sign!
    Got a late start today but was still able to accomplish more than I thought. I was able to complete all of the mortises and tenons for the sign. I decided to go deeper with the tenons for the arms and then miter the ends. This will give me more glue surface and a stronger tenon through which to drive a dowel pin.
    Here I have marked out the areas for the mortise.
    Here I switched to a larger bit to clean up the side walls a bit.
    All drilled out and ready for some chopping
    Next the tenons
    And a test fit
    The angled brace comes next
    www.wrworkshop.com
    5,533
    very cool project Rennie!
    -Ned
    11,825
    Looks stout. Good. Trivent is good people. I preferred the original name.
  1. Another sign
    By Darren Wright in forum Computer-Aided Equipment Project Showcase
    Last Post: 11-18-2015, 02:28 AM
  2. jimzilla sign
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 07-11-2015, 01:37 PM
  3. a sure sign...
    Last Post: 02-19-2013, 05:24 PM
  4. another sign
    By ken werner in forum Off Topic Discussion
    Last Post: 10-20-2011, 03:48 AM
  5. A New Sign
    By Randy Wynn in forum Off Topic Discussion
    Last Post: 11-06-2008, 08:13 PM
