Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 76
Thread: Fell off the brewing slippery slope
    13,437
    In a by chance conversation with an old co-worker, at lunch a few weeks back, I mentioned I was wanting to try brewing some beer. He mentioned that he had a Kegerator and some kegs I could have if I wanted them. He and his wife don't drink, but they used to own a KOA camp ground for a few years and he brewed root beer for the patrons there, it just sits in his basement now. He sent me pics and says he has 10 kegs to go with the setup, just needs a co2 tank. I'm picking it up this weekend.
ID:	85338 Click image for larger version.
ID:	85339 Click image for larger version.
    After some nudging I got him to charge me $200 for all of it though, I felt bad just taking it as none of this stuff is cheap. I know the kegerator new alone was about $600.
    After lots of questions to another member here, I think I've got a vague grip on things I'll need for brewing. I ordered this kit last night and some cleaners for the equipment. I'll wait until I get the equipment to order new o-rings, lines, and an additional tap or two. As long as there is some hard cider flowing from one off the taps, my wife will allow it to adorn the sunroom downstairs...at least the kegerator.
    Yorktown, Virginia
    5,009
    That was a fortuitous lunch. Looking forward to seeing how you progress.
    4,698
    Couple of things.
    First since that keg system had root beer running through it you will want to replace every (and I do mean every!) piece of rubber or plastic in the system or everything you put through it will taste like root beer (not in a good way). For the kegs that means new poppit valves, o rings (lid and tubes), pressure release valves (shop around for these, the process vary quite a bit and they aren't super cheap). Since you're returning 10 kegs you might do as well/better getting the gaskets from an industrial supply.. I used to have the mcmaster part #'s, and will see if i can dig them up (might still require to large of a buy, can't remember). For the tap on the kegerator replace the hose and corney connector with new. Since you plan to run cider through it you should also replace the shank assembly (that goes through the tower) and the tap itself with stainless. Cider will eat the chrome taps that come with this like candy (this might already have been done since soda eats them fairly bad as well but I wouldn't count on it). I'd also highly recommend replacing the tap itself with a "forward seal" tap, they get less gunky, have less contamination problems, and don't stick like the old rear seal ones do.
    If you can boiling outside is conducive to domestic harmony... I brewed on a stove for years but boil overs are.. Well to common and painful to clean up.
    Finally Welcome aboard the brewer train ! If you have any additional Q's would be happy to help!
    13,357
    Welcome to the dark side, We've got beer....
    13,437
    Thanks Ryan, appreciate the advice/suggestions. I think all the kegs are ball-locks, but will have to wait to see before I can order any new parts.
    13,437
    Beer trumps cookies.
    13,357
    +1 on brewing outside. Nothing like being able to just hose the down the floor if you spill something or make a mess.
    30,008
    But beer cookies...them are the best!
    4,698
    I think you confused cookies with cheese, but we'll forgive you
    Also meant to mention that the capper in that kit will make you sad (but all the cappers in kits would make you sad so.. this one is no different). If you get to a stage in your life where cleaning lots of bottles sounds like fun (I'll have what he's getting) you might want to invest in a slightly better capper. Likely not a huge problem since you're going to mostly keg anyway and for small numbers of bottles that capper is just mildly annoying instead of outright insanity inducing (which it would be for large amounts of bottles). Pretty much any of the overarm cappers work reasonably well. I mention this because if you do end up bottling and start to wonder if there is some magic to not breaking bottles and having half applied caps.. well .. yep there is... a new capper
    And really yes you should feel bad about that price! Straight up highway robbery!
    Nov 2012
    Wapakoneta, OH
    611
    For you guys that brew outside, can it be do on a turkey fryer or something like that? I'd like to try brewing, but so far have been intimidated by the equipment needed.
  1. And the front fell off
    By Drew Watson in forum Off Topic Discussion
    Last Post: 06-25-2010, 01:51 PM
  2. brewing table
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 11-07-2007, 05:54 AM
  3. brewing - diversion from earlier thread
    By Mark Kosmowski in forum Off Topic Discussion
    Last Post: 10-17-2007, 05:09 PM
  4. Auuuuuugh! *first slide down the slope*
    By Ned Bulken in forum Lathe Project Showcase
    Last Post: 10-08-2007, 02:00 AM
  5. The Front Fell Off
    By Dave Richards in forum Off Topic Discussion
    Last Post: 06-08-2007, 01:34 AM
Tags for this Thread
