Results 1 to 6 of 6
Thread: Bowl turning question
    Feb 2012
    2,749
    When turning aged or kiln-dried wood, is it still necessary to put it away and wait 6 months before finishing it, or can you just turn to final dimensions and have done with it. One of the pieces I am planning on is a mortar and pestle, which will have sides or about 5/8". The others are regular bowls with thin walls.
    Cheers,
    Roger
    3,132
    Roger there's no need to twice turn dry wood. The reason we twice turn wet wood, is because of the drying, and warping that is caused by it. Heck some folks like the warped effect that you get when it's finished straight from green to finish. (not me though)
    Feb 2012
    2,749
    Thanks for that, Stephen. The learning continues...
    Cheers,
    Roger
    May 2009
    Lafayette, Indiana
    2,380
    Roger I bought a couple "bowl blanks" from Woodcraft once (expensive). But they are dry and I could turn to final shape right away.
    Yorktown, Virginia
    5,017
    Roger,
    I agree with the others, but suggest you still be prepared for a little wood movement. Bowl blanks are usually pretty thick and when you open them up they almost always will move a bit.
    Feb 2012
    2,749
    Thanks again. I have several bowl blanks that I bought locally. I'm waiting to get a bit of experience before I waste that money.
    I have a piece of wood that I squared today. It is very heavy, reddish, has close growth rings (1/8 to 3/16") and has short dark streaks running the direction of the wood fibres. I'm thinking maybe red oak, and from the looks of the end, it was probably a beam in a building. I got it from my neighbour's firewood pile, where else. I have made some 2" thick pine blanks for practice.
    Cheers,
    Roger
  1. My attempt at turning a bowl
    By Rich Soby in forum Turning Tool Questions and Show & Tell
    Last Post: 08-21-2011, 10:41 AM
  2. Commercial bowl turning
    By Dan Mooney in forum General Woodturning Q&A
    Last Post: 10-20-2010, 12:12 AM
  3. I bow to you bowl turning gods!
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2009, 01:14 PM
  4. Just getting into turning. My first bowl.
    By Alan Trout in forum Lathe Project Showcase
    Last Post: 07-02-2008, 12:55 PM
  5. My 2nd Attempt at Turning a Bowl
    By Sean Wright in forum Lathe Project Showcase
    Last Post: 06-23-2008, 05:29 AM
Tags for this Thread
