Results 1 to 10 of 14
Thread: Poor Mans Dovetail Spline Jig
    Aug 2014
    St. Mary's, Georgia
    398
    I'm going to show how I make a Dovetail Spline jig, but I'm making 2 of them. First one is for the main dovetail an the second one is for a Inlay Dovetail
    First I pulled out a scrap piece of Baltic Burch Plywood 3/4 inch
    I'm going to making (2) X 7 Inch rips on the scrap
Name:	Jig for Dovetail Splines 01.jpg
    Next on each piece I'm going to make (2) 7 inch cuts an (1) 11 inch piece
Name:	Jig for Dovetail Splines 02.JPG
    Next on the 7" x 7" pieces I cut a 45 degree angle on one side,
Name:	Jig for Dovetail Splines 03.jpg
    As you can see in the picture there is a recess cut across the grain on the 11" piece. Here is why all corners on the project theses jigs are made for are sharp corners so I cut a recess in the center across the board I only went in about 1/8"
Name:	Jig for Dovetail Splines 04.jpg
    Next on the C/L I marked out for (2) 1" holes these hole are 3 1/2" from the recess on each side
Name:	Jig for Dovetail Splines 05.jpg
    Next thing I did I found some scrap Oak an cut some 45s for support latter in the thread
Name:	Jig for Dovetail Splines 06.JPG
    Now for the best alignment for this jig is to take it to your project an clamp the 7" X 7" pieces to the corner top an bottom with the long end of the 45s touching the wood , bring it close to the corner
Name:	Jig for Dovetail Splines 07.jpg
    While it is clamped check an see if the top plat sits nicely on the 45s, if not adjust until it does. On mine it looks great so I took the pieces off an put some wax paper on the corner an reattached the pieces
Name:	Jig for Dovetail Splines 08.jpg
    Double check fit-up an adjust as needed, If you are ready put glue on the 45s an set your top plate on an brad nail it in place
Name:	Jig for Dovetail Splines 09.jpg
Name:	Jig for Dovetail Splines 10.jpg
    Back in next thread
    https://www.facebook.com/BgCouger
    If you are going to make something nice, make it with a statement, use quality an do it right the first time
    Aug 2014
    St. Mary's, Georgia
    398
    Now next thing to do is get your 45 degree pieces of scrap an glue then in place an brad nail them in place this is the added support
Name:	Jig for Dovetail Splines 11.JPG
Name:	Jig for Dovetail Splines 12.jpg
    Now that I am making 2 of these I will make the other one on the other corner same way as this one
Name:	Jig for Dovetail Splines 13.JPG
Name:	Jig for Dovetail Splines 14.jpg
    Now I leave them in place until dry
    So be back tomorrow
    Aug 2014
    St. Mary's, Georgia
    398
    Well it time to finish the jig, the next step is to find what size of my guide bushing since my router bits are Half inch shank so I am using 5/8 bushing , so I got out my 3/8 inch strait bit and set it up in my router table
Name:	Jig for Dovetail Splines 15.jpg
Name:	Jig for Dovetail Splines 16.jpg
    As you can see I cut in a small run from one end to the first hole it helps me for setup an clean out when I cut the Dovetail Spline areas
Name:	Jig for Dovetail Splines 16-1.jpg
    Next thing I did is set the bit height to the highest it needs to be. I set my digital gauge to 0 an lowered the bit to 1/4" above the table then set my center point with the fence. Next I ran 1 grove through the holes an turned it around an did the same I was off by 1/32 from center so not to bad, I raised it an did another passes until I reached my max height
    Now I'm at the max height I need to make it wider so I marked where my fence is an moved the fence in small increment's until I needed to where I need to be for the bushing size
Name:	Jig for Dovetail Splines 17.jpg
Name:	Jig for Dovetail Splines 18.jpg
    Now here is what the jig looks like after cutting the grove for the bushing
Name:	Jig for Dovetail Splines 19.jpg
    Next I got out one of the test pieces an I set up the height of the bit an clamped my jig to the test piece, time to find out if its going to work for my project
Name:	Jig for Dovetail Splines 20.jpg
    Next I do my cut , this is the first time the jig is used so I'm also cutting the jig to for the router bit an it looks good
Name:	Jig for Dovetail Splines 22.jpg
    I removed the jig an checked my test piece
Name:	Jig for Dovetail Splines 23.jpg
    No blow outs an nice clean cuts so this jig is ready for the project, but before I do anything I mark the top an size of the dovetail bit used for this jig. I plan on keeping this jig for future projects
Name:	Jig for Dovetail Splines 24.jpg
    Now you can make this jig for strait bits also for splines for your bigger projects or an size of dovetail bit. Since I made 2 of these I will be making a inlay dovetail with the other one for future projects
    Thomasville, GA
    5,989
    This is the same subject matter you cover in your blanket chest thread, isn't it???
    Bill Arnold
    Aug 2014
    St. Mary's, Georgia
    398
    Yes it is here also so its available to all with out getting lost in the chest thread
    Aug 2014
    St. Mary's, Georgia
    398
    Here is what it looks like with the Spline in the cut
Name:	Jig for Dovetail Splines 27.jpg
Name:	Jig for Dovetail Splines 26.jpg
Name:	Jig for Dovetail Splines 25.jpg
    Nice tutorial Roy. Thanks for sharing slick little jig.
    Aug 2014
    St. Mary's, Georgia
    398
    Your welcome but there is one more section coming up for it, its the inlay part of the dovetail that's the second jig made hopefully I get it done tomorrow
    Constantine, MI
    7,887
    Ditto!
    www.wrworkshop.com
    Quote Originally Posted by Roy Millsaps View Post
    Excellent!
  1. Poor Mans Drop Cord
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 12-01-2014, 04:26 PM
  2. Miter Spline Jig
    By Ned Bulken in forum Jigs and Fixtures
    Last Post: 08-17-2012, 02:51 AM
  3. New to this site, "The poor mans wood shop"
    By Daniel Stankovich in forum General Woodworking Q&A
    Last Post: 07-18-2008, 11:15 AM
  4. Corner Spline Jig
    By Steve Ash in forum Jigs and Fixtures
    Last Post: 12-23-2006, 07:39 AM
