Results 1 to 5 of 5
Thread: Tablesaw Sled Support
    9,077
    I have been jealous when I see others who have made these. Not a must-have but, certainly a convenience and a safety feature. I am on a mission to knock things off of my "jigs to make" list while whittling down my scrap bin contents.
    I cut a piece of 3/4" ply that fits between the miter slots by length and between the front fence tube and the table top by thickness. I size it to set flush with the table top.
Name:	TS Sled Support (1).jpg
ID:	85623 . Click image for larger version.
Name:	TS Sled Support (2).jpg
    I choose another piece of scrap and carefully calculate the exact geometry required to avoid hipbone bruising on sharp corners during use. I also add a scrap of pegboard to let the supporting surface rest firmly on the fence tube.
Name:	TS Sled Support (3).jpg
ID:	85625 . Click image for larger version.
Name:	TS Sled Support (4).jpg
    I tape a bit of pegboard scrap to cause a slight angle while I sand to create an easement so that the sled won't catch if the support jig should shift a bit. The support sets fine as it is but, I am not one to trust to gravity and friction where power tools are concerned so, being a wimp I added a little push clamp to keep things put while in use.
Name:	TS Sled Support (5).jpg
ID:	85627 . Click image for larger version.
Name:	TS Sled Support (6).jpg
    And it goes on here:
Name:	TS Sled Support (7).jpg
ID:	85629 . Click image for larger version.
Name:	TS Sled Support (8).jpg
    And looks like so in use:
Name:	TS Sled Support (9).jpg
ID:	85631 . Click image for larger version.
Name:	TS Sled Support (10).jpg
    This is not something I have needed often but, when you want one is not the time to stop and make one (usually, although I do have those moments ). It is particularly useful when using a sled at its capacity.
    5,174
    Great idea! Gives me another one for what I am doing at the moment, too. Double win!
    13,454
    Oh now I'm going to have to Ste...err..."Borrow" that idea.
    I'll second the "great idea" comment.
    3,134
    I like this.
    My sled doesn't have the block on the back side of the fence for the blade to bury itself into. I made the sled a little longer than the table-saw top which has a router table as the left wing. There is a small stop block on the bottom of the sled & another stop block screwed to the edge of the router table that stops the sled at the right time that allows for a completed cut but stops the sled before the blade can come through the back side of the fence.
  1. Third hand support
    By larry merlau in forum Jigs and Fixtures
    Last Post: 01-05-2013, 01:40 AM
  2. dresser support question?
    By larry merlau in forum Designs, Plans and Sketches
    Last Post: 02-13-2012, 02:43 AM
  3. TS Sled Support - Very Simple
    Last Post: 01-01-2011, 03:50 PM
  4. Vertical Tablesaw Sled
    By Vaughn McMillan in forum Jigs and Fixtures
    Last Post: 12-03-2006, 04:10 PM
