Results 1 to 6 of 6
Thread: Jet 1442 Lathe Question
    SE Minnesota
    2,524
    I've been looking for some iron legs to use for an industrial styled table and was wondering about using the legs for a Jet 1442 or equivalent. Is it possible that someone who has one could give me a few dimensions such as the height, width at the bottom and the top?
    Thanks in advance.
    Thomasville, GA
    5,992
    Dave, I don't have one but here's a list of specs from the Rockler site:
    • Model Number: JWL-1442VSK
    • Height: 44"
    • Width: 17"
    • Length: 60"
    • Swing Over Bed: 14"
    • Swing Over Tool Rest Base: 10"
    • Distance Between Centers: 42"
    • Headstock Taper: MT-2
    • Spindle Nose: 1" x 8 TPI
    • Tailstock Taper: MT-2
    • Hole Through Tailstock: 3/8"
    • Ram Travel: 4"
    • Centerline of Spindle to Floor: 43-1/2"
    • Headstock Movement: Pivot 360 and Slide
    • Indexing Positions: 36
    • Style: Leg Stand
    • Bed Construction: Cast Iron
    • Motor Voltage: 115 V
    • Prewired Voltage: 115 V
    • Motor Current: 8 A
    • Motor Phase: 1 Ph
    From this, the overall length is 60"; height of legs would be about 36".
    Bill Arnold
    SE Minnesota
    2,524
    Thanks Bill.
    I guess from your calculation of the legs being about 36" tall, they're too tall for what I was wanting.
    Thanks again.
    D
    Yorktown, Virginia
    5,009
    SE Minnesota
    2,524
    Hi Ted,
    Yes. I did look at those and the shorter ones might be an option. They would require the table to be deeper than I really want. I was just hunting for other possibilities, too.
    Yorktown, Virginia
    5,009
    With your skills, it would be relatively easy to have your own design fabricated by a metal shop. Plasma cutters abound and many shops have CNC plasma machines that can crank out something in heavy plate in no time at all, complete with frills and flourishes...it's amazing. Weld on some top and bottom brackets and you're good to go. Just a thought.
  1. JET 1442
    By wayne tamashiro in forum Old Ads
    Last Post: 12-23-2010, 01:45 AM
  2. Lathe question
    By Jeb Taylor in forum New Tools
    Last Post: 07-05-2010, 01:10 AM
  3. Lathe Question
    By Garry Foster in forum New Tools
    Last Post: 03-31-2010, 01:13 PM
  4. Casters for Lathe Question
    Last Post: 01-29-2010, 12:50 AM
  5. Question About Lathe's
    By Scott Custer in forum General Woodturning Q&A
    Last Post: 11-20-2007, 12:27 PM
