Results 1 to 4 of 4
Thread: Pink Insulation Foam vs HDU vs wood for 3D images
    East Freeetown, Massachusetts
    3,022
    I Tried the pink insulation foam - not good
    I ended up with HDU - did exactly as expected - this is the way to go - proved out over and over again
    3,022
    Just to mention - I consider this as part of my house remodeling project
    4,699
    Those are cool! That's going to be quite the menangerie.
    I have to say that, although I agree its not what you'd want, the pink foam came out way better than I'd have expected it to. Frankly I expected it to be a complete disaster whereas its actually pretty good considering.
    It seems like the HDU also has the advantage of dimensional stability over time, although maybe something like good quality piece of beech (or even a clean piece of maple) might be close enough.
    3,022
    I think a brand new sharp cutter would have worked better in all the cases. My cutters are getting dull and need to be replaced.
    I did cut pink foam with better results another time - but my cutters were sharper back then. They have seen a lot of use.
  1. spray foam..
    Last Post: 11-23-2011, 11:48 PM
  2. Insulation question - rigid & spray foam hybrid
    By Matt Ducar in forum Carpentry and Construction
    Last Post: 02-27-2011, 05:55 PM
  3. seat cushion foam
    Last Post: 04-12-2009, 10:24 AM
  4. Foam Brushes
    Last Post: 07-29-2008, 12:38 PM
  5. Spray Foam Insulation
    By Joe McCormick in forum Carpentry and Construction
    Last Post: 02-04-2008, 01:18 PM
