Results 1 to 6 of 6
Thread: Fixed the problem with the instrument cluster on my Chevy Silverado
    The problems started several years ago first the Tach then the Oil pressure then the speedo quite working and finally all the gages quit. I did some research and found out the all GM trucks, Tahoe and Suburbans and Tahoe's built between 2003 and 2007 have a problem with the stepping motors that are used fail. Mine is a 2005. Speedo shops wanted Big bucks to fix the problem so I did a lot of research and found several U-tube how to fix it showing the correct procedure. I kept talking about it and finally decided to get it done. I ordered this kit on Amazon for $38. The only tools needed were a soldering Iron, solder sucker and a 7 MM socket. The whole job took less then 2 hour start to finish. Just thought I would post this in case anyone else out there has the same problem
    30,014
    I saw the title of this thread and figured you'd be showing pics of your new Ford truck.
    h
    nah my Silverado's just getting broke in its only got 180K miles on it.
    S E Washington State
    3,777
    Glad you got it fixed. I had a problem with the instrument cluster on a Chev PU I owned several years ago. The Chev guys told me the only fix was to replace the cluster to the tune of $700 plus. Did some research on the web and found it was a fairly common problem and there was a place in Canada that would fix it for around $100. I took the cluster out, sent it, it came back in less than 2 weeks fixed and I never had the problem again.
    "We the People ......"
    Yea Paul, I was getting the same kind of quote and I didn't want to be without a truck for a week or two, that why this was such a great find.
    Mar 2014
    Humid Gulf Coast
    542
    Easy repair with a good payoff.
    It's kind of fun to do the impossible
  1. OK all you IT gurus here is a problem for ya -- Fixed
    By Don Baer in forum Site Questions and Test Posts
    Last Post: 05-04-2015, 01:13 AM
  2. 1936 Chevy assemblyline
    Last Post: 07-23-2012, 01:30 AM
  3. Chevy Convertibles
    Last Post: 11-09-2011, 01:03 AM
  4. Ford or chevy or dodge
    By Doug Sinjem in forum Off Topic Discussion
    Last Post: 09-13-2007, 12:46 PM
  5. My Newest Tool - 2007 Chev Silverado
    By Rick Doyle in forum Off Topic Discussion
    Last Post: 12-13-2006, 09:51 PM
