Results 1 to 3 of 3
Thread: Draw Slides videos on how to mount
    12,260
    I am fitting draws to my new router table and have never before mounted full extension slides.
    Here are some good reference videos about the topic
    This guy really makes it simple
    And here are two videos by famous Charles Neil that gives a good overview of the whole topic with loads of little tips. No too much in the way of actual practical how to detail but very good overview if you a rookie like me.
    And a source if you need it, not the cheapest but hey they close and work properly. You get what you pay for says Charles.
    http://www.leevalley.com/en/Hardware...,43614&p=43616
    Yorktown, Virginia
    5,021
    Thanks, Rob. Watched 'em all....good info.
    Thomasville, GA
    5,998
    Good instruction on all of the videos. The guy in the first one needs to tone down the "background" music so he can be understood better.
    I've simplified (for me) the process of installing drawer slides by making some guides.
    In the foreground of this photo is the drawer side gauge. Behind is the cabinet side gauge. Both are just some scrap that I cut and marked for a particular type of slide mechanism. I have another set that is similar for a different type of slide.
    To use the cabinet side gauge, I cut a spacer to set the elevation of the drawer if it's not right on the bottom of the opening. This gauge has holes to match those I'll use on the slide itself. I run a pilot bit through the hole into the cabinet side. Then, it's a snap to set the slide and screw it into place. For the drawer side, I set the drawer on the gauge and run a pencil line; then it's just a matter of matching the holes in the slide to the line and punch or drill pilot holes.
    Why did I make each gauge different? Because I can, I guess.
    Bill Arnold
  1. Replies: 19
    Last Post: 10-13-2012, 11:35 AM
  2. Draw leaf table
    By Wout Louwers in forum Designs, Plans and Sketches
    Last Post: 02-07-2010, 11:18 AM
  3. Who Needs a Computer to Draw Furniture?
    Last Post: 07-11-2008, 12:35 PM
  4. How to draw an arch in SU?
    By Charlie Schultz in forum Designs, Plans and Sketches
    Last Post: 06-04-2007, 05:19 PM
  5. SKETCHUP Draw Leaf Table
    Last Post: 05-08-2007, 01:37 PM
