Results 1 to 10 of 18
Thread: First turned box
    5,533
    First turned box
    Ned
    -Ned
    5,167
    Addicted! You are now officially addicted. Good on you. Looking good. Looks like poplar? You have the mechanics down. Finesse will come. Keep at it!
    5,533
    First turned box
    Thanks Carol, not poplar, maple. I always wondered about turned boxes. Now I 'get ' why they're so fun!
    When I parted the top off I lost the material in the center, so I get to turn a finial. Plus it needs a coat of wax or some such.
    Ned
    -Ned
    564
    Honestly, Ned I don't know why you think it needs a finial. I think it looks great just as it is.
    The beauty in a turned box to me is how carefully you choose the wood, particularly the end grain which is in some ways the most prominent part of a box. If the end grain is dull you can inlay a contrasting piece of wood to brighten it up and make it beautiful. I do that all the time with plain old maple, curly maple, quilted maple and birdseye maple. The long grain of those woods is beautiful but the end grain is blah. Inlaying something else to dress it up makes a bland box into something special.
    For example here is a maple box with a scrap of koa inlaid into the top.Click image for larger version.
Name:	Maple-Koa 1-1 (Small).jpg
ID:	86236Click image for larger version.
Name:	IMG_1598 Open 6X4 (Small).JPG
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    5,533
    Quote Originally Posted by Mike Stafford View Post
    Mike, when I parted off the lid from the blank everything was going fine... until the last 1/4 "... which broke off and stayed with the scrap part. It just tore out, leaving a rough edge. Design mod opportunity, not that I had much of a design beyond 'make a box.' I'm about to head back out to the shop, I'm visiting friends and want to turn a NE bowl for them.
    -Ned
    Yorktown, Virginia
    5,009
    Nice box, Ned. You're hooked for sure. Now firewood will never look the same and if you hear chainsaws in the neighborhood you will go see if it's turnable and beg a few chunks, and you will always slow down to check out every pile of wood you see out by the curb.
    5,533
    Ted, yep. I can see it now...
    Is it 'bad' that I just ordered another turning tool, and a couple of pen kits? (might as well, since I was on PSI already)
    -Ned
    Aug 2008
    Reno, Nv
    3,632
    Great job Ned!! Print off Mikes tutorial if you haven't all ready...the Gold standard by which all others are judged. You are on a roll!!
    564
    Quote Originally Posted by Ned Bulken View Post
    Ned, somehow the fact that you ended up with a hole in the lid totally escaped me. I still think that you could inlay a contrasting piece of wood that would be visible from both sides. I re-read your post and now understand that you first hollowed the lid and then parted it off from the main blank. If you are going to use that technique you have to 'measure twice' and leave enough wood to keep that splitting from happening. If you follow the box turning steps advised by Raffan that kind of thing will not happen very often.
    I suggest you spend a couple of dollars and buy Richard Raffan's video and book entitled Turning Boxes. The hollowing can be done without a Forstner bit. I can hollow out a box in less time than it takes you to set up and use a Forstner. The inside rounded hollow you have could be cleaned up/squared up in just a minute or two with a square scraper. Square boxes should have an interior that closely resembles/mimics the exterior.
    Learning to use a square scraper is an important step in creating boxes with suction fit lids.
    If you are interested I will be happy to send you a PDF of one of my box turning articles. Just PM an e-mail address.
    Thomasville, GA
    5,992
    Good job, Ned! You're gettin' there!!!
    Bill Arnold
  1. I need something turned
    By Rennie Heuer in forum General Woodturning Q&A
    Last Post: 07-27-2015, 11:55 AM
  2. PM's not turned off?
    By larry merlau in forum Site Questions and Test Posts
    Last Post: 11-25-2012, 05:08 PM
  3. Turned My First .............
    Last Post: 06-01-2010, 09:26 PM
  4. turned box
    Last Post: 07-12-2008, 11:33 PM
  5. Turned another pen
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 05-21-2008, 03:50 PM
