Results 1 to 10 of 12
Thread: Sanding source?
    5,533
    Sanding source?
    OK guys & gals, I'm in the 'rough out' stage of my massive batch of turning. I can see that I'll eventually need more '80 grit gouge' material etc... Woodcraft has the 'woodturner's pack', which gives a decent range of grits. I have two rolls of 1" sandpaper 120 and 240 grits, enough that It'll be years before I use it up. I can pick up the replacement grit rolls at $5.50/ea for the higher grits, but there has to be a better source for paper, and those foam backed sanding pads that chuck into a drill/driver. Thanks in Advance...
    -Ned
    30,008
    I use Vince's products. The vast majority of my sanding is on a sander (drill-mounted spinning pad or 2" ROS). I use his blue disks.
    http://vinceswoodnwonders.com/store/
    Best bang for the buck I've found.
    What little lathe sanding I do with sheet paper I do with Norton 3X paper cut into small pieces.
    4,698
    While I love me some Norton 3x paper (Norton 3x paper is best paper as far as paper goes although some of the 3M products give it a run for the money) I would have to ask if you're not yet using Mirka Abranet, why not!
    While I won't go quite so far as to say its the best thing since sliced bread its darn close. Costs a smidge more but lasts a lot more than a smidge longer, cuts cleaner and doesn't clog up nearly as fast (expecially if you're doing turn->finish on not entirely dry wood and want to get a first pass sanding done).
    The main downside is that it wants to be either "open" (no backer - aka hand sanding and we all know how much fun that is) or you need positive airflow (which means a sander hooked up to a vacuum) which in turn means that I can't use it on things like my little 2" power sander setup which is a darn shame! This means it wouldn't work for Vaughns setup for beans.
    Still the cats meow for hand sanding or for larger sanders that have decent airflow though (do get the mirka abranet backing pad or you'll burn up the stock velcro hooks on the regular pad on your sander ).
    5,533
    Thanks Vaughn, I knew it was v-something... unfortunately he's sold out of the starter kits. That's ok, I'm not ready to order 'today' anyway. #budgetcrunchsucks
    -Ned
    May 2009
    Lafayette, Indiana
    2,380
    I too have used Vince's products. Good quality and price.
    Feb 2013
    Clyce, Texas
    185
    I've had great luck with Color Grit Abrasive from Craft Supply: http://www.woodturnerscatalog.com/p/...-Abrasive-Roll . It's a little more expensive than the Woodcraft rolls, but you get a little more (295 sq in vs 240 sq in). The thing I like about it is the cloth back is color coded so you always know what grit you're using. Only goes up to 400 grit.
    Austin, Texas
    1,448
    ... (do get the mirka abranet backing pad or you'll burn up the stock velcro hooks on the regular pad on your sander ).
    I bet you have a Festool sander. Their "stick fix" hook and loop (or whatever it is called) has far longer hooks on the sanding pad, which go all the way through abranet and get worn off (DAMHIK). I have not had the problem on my Bosch and other sanders.
    Charlie Plesums, Austin Texas
    Oct 2009
    Harrisburg, NC
    140
    Quote Originally Posted by Ned Bulken View Post
    I am assuming you are talking about bowls/platters. You are not sanding "rough outs" which you will put back to dry are you?
    If so there is no need.
    Another + for Vinces. I use the blue flex but I understand he has a new green flex that some say are even better.
    Last edited by Vaughn McMillan; 09-30-2014 at 03:44 PM. Reason: Fixed broken QUOTE tag.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    5,533
    Sanding source?
    Mike, no , I'm definitely not sanding the rough outs. The wood will move. I'm looking down the road to when I am at the finish turning stage .
    Ned
    -Ned
    4,698
    Quote Originally Posted by Charlie Plesums View Post
    Right in one! Interesting to hear that the Bosch & friends don't have the problem. The interface pad isn't horribly expensive though (once the initial lesson is learned...)
  1. Source for the dremel sanding sheets
    Last Post: 10-21-2009, 02:57 PM
  2. Source for bun feet
    Last Post: 05-23-2009, 01:23 AM
  3. Source for old motors
    By Paul Hubbman in forum Old Iron
    Last Post: 07-02-2008, 08:55 PM
  4. SuperNova2 jaw source
    By Chip Charnley in forum Turning Tool Questions and Show & Tell
    Last Post: 10-19-2007, 05:42 PM
  5. looking for source
    Last Post: 06-19-2007, 11:30 AM
