Results 1 to 10 of 13
Thread: YAB-a yabba bowl...
    5,533
    YAB-a yabba bowl...
    My friends Helen & Scott gave me another cherry log the other day, and Helen even cut it in half for me! Here's the first blank roughed out... about to go out and start the other half. Approximately 8-8.5" initially. I really need to work on my rounding cuts on the bandsaw, it was really unbalanced when I first spun it up.
ID:	86263Click image for larger version.
Name:	bigger cherry rough1.jpg
    -Ned
    Jul 2007
    DSM, IA
    5,719
    Well it's round now Ned! Hope you get your heater done for your shop soon...or you'll be freezing out there when you return these.
    My Website
    30,002
    Keep on crankin' them out, Ned.
    I typically would go with a bit thinner walls on a roughout to lessen the chance of cracking. It's always a roll of the dice until you see how much a particular batch of wood wants to move. I realize you're leaving it thick so you have enough wood to re-turn it round after it dries, but if the walls are too thick, it'll crack instead of warp. Since you have a fair amount of wood to play with, I'd suggest trying some with thinner walls and some with thicker walls. Doing so can help you find the "sweet spot" between cracking too much and warping too much.
    5,533
    YAB-a yabba bowl...
    I went with roughly 10% of the bowl diameter (gleaned from bill g's DVD) in this case it is .75 or 3/4" . I might be a shade over that... But I can easily chuck it back up tonight
    Ned
    -Ned
    Yorktown, Virginia
    5,002
    Nice! I love the smell of fresh cherry. Save some of the shavings for smoking ribs and such
    30,002
    Quote Originally Posted by Ned Bulken View Post
    Ned
    Generally the 10% is a good starting point, but for a bowl that small, 3/4" walls may still be prone to cracking...it really depends on that particular batch of wood and how much it wants to move. Similarly, being a relatively small diameter, it's less likely to warp than a larger bowl. After some experimentation on both sides of that 10% number, you'll have a better feel for how that batch of wood responds. (And I corrected the suggestion in my previous post to say try some thinner and some thicker.) One of the fun (and challenging) things about drying green turned pieces is that it varies by wood species, moisture content (freshness), and of course, climate. What works for me in the desert southwest might be totally wrong for you on your side of the country. That why I'm suggesting trying a few different things to see which is better for you.
    15,806
    Looks great Ned, and I'll second what Vaughn is saying for sure.
    One of the big mistakes I kept making when I started to roughout green bowls was to leave the base too thick, this was the source of many of my first failures at roughing, as the sides of the bowl were about right for thickness but the base was twice that or more, the sides moved a lot and cracked.
    Are you going to DNA dunk the roughed out bowls? I found with fruit wood, and maybe cherry is or is not fruit wood, the DNA bath helped a lot with the roughed out blanks NOT cracking.
    Keep at it!
    5,533
    Here you go guys, I re-chucked it, and fought the already moving blank into submission. I took the rim down to about 1/2" and the base is at about 3/4. I have to wait until next paycheck to pick up some DNA and a project bucket at the Borg, looking forward to accelerating the process!
Name:	bowl thinner 1.jpg
Name:	fair curve1.jpg
Name:	fair curve 3.jpg
ID:	86286Click image for larger version.
ID:	86287Click image for larger version.
ID:	86288Click image for larger version.
ID:	86289Click image for larger version.
ID:	86290Click image for larger version.
    -Ned
    30,002
    Looking good, Ned. Get that baby wrapped up in paper if you haven't already.
    Personal opinion, but when I stopped using the DNA bath and just started wrapping the bowls in paper, I saw no significant difference in how fast rough-outs dried or how much they moved while drying. It seems that with the DNA bath it took about 3 months for a piece to dry, and without DNA it took about 12 weeks. And I was pretty unscientific about the paper wrap. I'd wrap the bowl in three or four layers of paper, then punch a hole through the paper with my finger in the inside of the bowl to allow air to reach the inside of the bowl. (By letting the inside of the bowl dry slightly faster than the outside, it helps "pull" the wood in, which helps reduce cracking.
    Keep in mind that there are more ways of drying rough-turned bowls than there are woodturners. Try a few and see what works best for you.
    4,698
    Those proportions look a lot closer to correct to my eye.
    One other caveat is that any "square" or "sharp" edges seem a lot more likely to crack. Not sure if that's bad luck on a small sample size but it generally seems true.
  1. A bowl and a bowl tweaker
    By hu lowery in forum Lathe Project Showcase
    Last Post: 11-03-2015, 04:07 PM
  2. my fifth first bowl!
    Last Post: 05-09-2013, 11:17 PM
  3. bowl and
    Last Post: 02-20-2011, 02:48 PM
  4. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
  5. 2nd Bowl
    By Ed Nelson in forum Turning Tool Questions and Show & Tell
    Last Post: 08-08-2007, 06:10 PM
