Results 1 to 6 of 6
Thread: Sander Mobile Base Improvement
    I seem to be caught in an endless list of to-do's for the shop that have little to do with actually making something. My Disc / Spindle unit didn't come with a mobility option. Not really a problem, I just factored in a 'wheelbarrow' style solution when I built the drawers into the base. Due to where the sander lives, I found myself moving it about more than I thought I would. This made me unhappy since I more often than not grabbed it by the table even though common sense tells us not to lift our tools by such things. My main problem is the difference in elevation between tablesaw, outfeed and sander. It makes it cramped for all but the smallest items.
Name:	G0529 Cab (22).jpg
ID:	86294 . Click image for larger version.
Name:	G0529 Cab (23).jpg
ID:	86295 . Click image for larger version.
Name:	G0529 Cab (24).jpg
    My first thought was to build an elevated mobile base to bring the disc table level with the others but, that rapidly got complex and costly materials-wise. I was also getting so involved in "making a base" that I had veered far afield from the problem I was trying to solve. I stepped back, had a cup of coffee and thought about it. I had already built structural reinforcement into the cabinet to take the place of the solid front panel I removed when I built in the drawers.
    I have a Rockler mobile base kit on my edge sander and it is designed to have the lift-wheel-pedal thingy move from one base to another. I simply sized a piece of hardwood, ran bolts through it, the metal cabinet and the internal supporting structure and viola. Now its just a step of the foot and she rolls right out.
Name:	G0529 Cab (25).jpg
ID:	86297 . Click image for larger version.
Name:	G0529 Cab (26).jpg
    12,247
    Oh man i wish i had seen this thread before i put the casters on my router table.
    I have one of those mobile wheel things and looked at how to fit it but was at a loss for a nice solution for the two wheels. You solved that. I originally wanted my cabinet flat on the floor with 4 solid fixed feet.
    Mmmm food for thought gonna have to review if i can make a change and keep my height somehow.
    Thanks Glenn.
    She sets flat on her four rubber corner skids Rob. The back (side?) wheels only engage when the opposite side is raised.
    S E Washington State
    3,777
    Great solution. My shop is small do all power tools have to be movable. I have three of my movable tools on homemade type rolling whatamacallits because I have never found commercial ones, that I can afford, that work very well. I really like what you did here. Easier to make than what I made, doesn't raise the equipment when the equipment is in use and that adds to stability. Great solution.
    "We the People ......"
    Apr 2008
    Independence MO
    557
    Reminds me of the factory setup of the Ryobi BT3000 series saw.
    Why is it, we seem to over think things?
    13,437
    Nice solution Glenn, thought you were going to add some wheel borrow handles there for a moment.
  1. Mobile base question
    By Mohammad Madha in forum General Woodworking Q&A
    Last Post: 11-27-2012, 10:14 PM
  2. Mobile base on a TS?
    Last Post: 07-07-2011, 12:38 AM
  3. Delta mobile base
    By Rick Levine in forum Hot Deals
    Last Post: 09-23-2007, 04:12 PM
  4. Mobile base for table saw
    By Dennis Thompson in forum General Woodworking Q&A
    Last Post: 06-13-2007, 01:06 AM
  5. FS: Delta 50-296 mobile base
    By Doug Shepard in forum Old Ads
    Last Post: 04-26-2007, 12:56 AM
