Results 1 to 10 of 18
Thread: Extension table fail
    5,167
    Sanded rust off the extension table to the Timberline saw this morning. This was under all the rust.
Name:	extension table 4.jpg
Name:	extension table 3.jpg
Name:	extension table 2.jpg
Name:	extension table 1.jpg
    Too light to be a boat anchor. Too big to be a paper weight. To unstable to again be an extension table. Requires skill and tooling I don't have to repair it. Too expensive to send out. On to Plan B, whatever that is.
    Feb 2012
    2,746
    Well, that sucks! Could you replace it with, say, thetable saw router table extension from MCSI, and kill two avian exemplars with one petrous fragment? It's a nice, heavy chunk of cast iron.
    Cheers,
    Roger
    30,002
    Bummer!
    Mar 2014
    Humid Gulf Coast
    542
    I wonder if epoxy could bond it well enough to use?
    If so, some autobody filler inthe gouges and hard epoxy paint on top might give you a useable part?
    It's kind of fun to do the impossible
    4,698
    That last picture that shows the grain of the metal is interesting in its own right.
    The other half might be useful as a lapping plate or something similar if its flat enough.
    I had replaced a stamped wing with a white oak framed slab of 3/4" MDF on one of my saws. It served me for years and served my dad for nearly as many. Sure its not CI but, it certainly works.
    13,431
    Re: Extension table fail
    I've done the same as Glenn. Worked well.
    Sent from my SPH-L720 using Tapatalk
    Yorktown, Virginia
    5,004
    I like Glenn's fix, if you can't find someone to weld it.
    ..and kill two avian exemplars with one petrous fragment? ...
    5,167
    3 of the 4 bolt holes that hold it to the main table are broken out and/or cracked. This one is a goner. I have another cast iron extension table or two somewhere, but that is not likely the fix for this one. Likely it will be a variation of Glenn's extension. The upside is that the entire assembly will be lighter. Since this is to be a mobile job site saw, that is not a bad thing. Build of mobile cab to begin later in October when I get back from my out of state assignments.
    Jan 2009
    Carthage,Mo
    880
    I like Darren's fix. Clean and neat. Makes me wonder if saw is ever used? Looks to clean for company work.��
  1. Table saw extension
    By Ken Cook in forum Jigs and Fixtures
    Last Post: 03-20-2011, 05:58 AM
  2. Extension table for my Grizzly G0691
    By Ronald Coates in forum Flatwork Project Showcase
    Last Post: 01-31-2010, 12:22 AM
  3. router table-tannewitz-extension wing
    By edward alexander in forum Jigs and Fixtures
    Last Post: 02-13-2009, 04:05 PM
  4. Bench dog router table extension
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 01-27-2009, 03:08 PM
  5. Table Extension Question
    Last Post: 01-31-2007, 02:04 PM
