Results 1 to 10 of 10
Thread: Blew out another bowl :(
    Feb 2012
    2,747
    I was turning another practice bowl in pine, and had shaped the outside and was well on my way to finishing the inside, when I went to shave off a little wood about 2/3 of the way to the rim, on the inside. I immediately got a catch, and quickly realized that I had blown away about half the side of the bowl. Now, this wasn't the first catch I had in this attempt, and I think it may have something to do with the way I am presenting my bowl gouge to the wood.
    So, if I am starting to turn the inside of the bowl, how do I present my tool to the wood? Once I have hollowed out most of the bowl and want to make the walls a little thinner, do I present the tool the same way? Should I give up and take up knitting?
    Thanks for any advice. Oh, this was a practice bowl again, so I am not upset about it, except that I want to get the technique right.
    Cheers,
    Roger
    Yorktown, Virginia
    5,011
    Roger,
    Depending on how thick the walls were to start, it might be tough to make them a little thinner after you've already shaped the bowl. At that point. the sides of the bowl are thin enough to have developed some flex as it turns and you end up taking uneven amounts off the piece. Any pressure from the tool accelerates the flex, promoting a catch-- although I've had some luck shear scraping with sharp tools. As a general rule, after shaping the outside, try and establish final wall thickness at the rim and gradually work that thickness down the wall until the inside is fully shaped and avoid going back to the rim.
    Feb 2012
    2,747
    Thanks for that advice, Ted. When I measured the wall thickness, I was about 1/16" thicker in a band where I described. I'll try to avoid that in the future.
    Cheers,
    Roger
    Dec 2008
    Portland, Oregon
    1,898
    I just say "Tool this is Bowl, Now play nice!"
    Jesus was a Woodworker
    Oct 2009
    Near Gassaway,West Virginia
    105
    I use a large scraper to finish the inside. Very fine cuts is the answer and it saves a lot of sanding.
    Fred
    steercreekwood.com
    5,533
    hard to 'diagnose' technique from a description... and y'all know I'm no expert. That being said, I can say that pointing the tip of the bowl gouge parallel to the outer wall when I start the swing on the inside works pretty well for me. Sometimes means the handle is way over yonder as the cut starts, but once the cut gets going and riding the bevel you just follow along.
    -Ned
    Feb 2012
    2,747
    Quote Originally Posted by Fred Belknap View Post
    D'oh! Shudda thotta that. I have a very nice round scraper.
    Cheers,
    Roger
    Aug 2008
    Reno, Nv
    3,632
    Scrapers should be very, very heavy for bowl and platter use. 3/8x1-1/4" is a good size. Doug Thompson has one of my favorites. For a bowl gouge, there is a roll move taking the gouge 90* from the flute up start position. Once you get that move down...you'll be in business!
    30,014
    Roger, I encourage you to look into a local turning club and attending a meeting or two. Invariably, there will be members there who'd be glad to spend a few hours with you in the shop (theirs or yours) mentoring you. A couple of hours with an experienced turner can save countless hours and untold frustration as you try to learn the basics. All the Internet advice and YouTube videos in the world can't compare to a bit of one-on-one help.
    Oct 2009
    Harrisburg, NC
    140
    I agree with Ted to work in about 1 to 1-1/2" increments from the rim down.
    Lyle shows doing this with a natural edge but the same procedure is used for a normal bowl.
    It doesn't compare with hands on but is pretty good for a video. He is turning complete from green but it is the same with a finish turning if the blank was set back to dry.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
  1. A bowl and a bowl tweaker
    By hu lowery in forum Lathe Project Showcase
    Last Post: 11-03-2015, 04:07 PM
  2. Look who blew in from Sacramento...
    By Sharon Korn in forum Off Topic Discussion
    Last Post: 09-08-2013, 07:14 PM
  3. Blew one up today
    Last Post: 02-03-2009, 09:35 PM
  4. Blew up my planer the other day!
    Last Post: 06-01-2008, 03:02 AM
  5. I blew it, no pictures.
    By Frank Fusco in forum Lathe Project Showcase
    Last Post: 12-03-2007, 05:35 PM
